Thread: Today i did a radical thing !!
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Default Today i did a radical thing !!
    I shortend the piston length in my Egr valve So as to mechanically reduce the amount the Egr valve was open/could open !! I removed approx 4mm.
    I refitted & drove the car . No Check engines so far !! Idled Ok & pulled strong, With lots of low down torque..
    I'll let you know what it is like after a few Miles
    The bit that is arrowed is the part i reduced in length, Mine stuck out further than the one in the Pic as mine was not seized in the solenoid ..
    Dean
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    good work m8 hope it goes well for you how did you shorten the pin
    lanark
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    what exactly is the egr valve and what does it do ???????
    Regular Member Steel's Avatar
    Sheffield
    Trim : Sri
    The EGR valve allows exhaust gasses to be recirculated (Exhaust Gas Recirculation) and reburnt to reduce emissions. Basically it is supposed to put unburnt fuel back in, which it does to a point but given the current state of engine management there shouldn't be that much to be reburnt. It kind of works but the engine would work a lot better without it, they much prefer to breath fresh air, especially cold damp air, not hot dry air!
    Nov 2007
    Staffordshire
    Quote Originally Posted by glynn View Post
    I stripped down the Egr as per the proper method
    http://forum.vectra-c.com/showthread.php?t=45867
    I must say, My pin was not seized, But the solenoid body was really full of Soot
    Then Hacksawed & filed the pin, Then re-assembled. After 40 Miles of driving it appears to perform Ok, Feeling more torquey, I think this is down to not as much burnt gas entering the combustion chamber low down & the space being filled with Fresh air , as such.
    I have not yet driven it from an overnight proper cold start, but i cannot see it being a problem ..
    It was not to much of a risk doing this, as i am the proud owner of Two Egr valves for the Cdti 150 Engine
    Dean
    Sunny Dartmoor
    Good luck with this mate,sounds a great mod you've done..........
    lanark
    Year : 2012
    Mileage : 9k
    thanks for the info but surely if it puts unburnt fuel back in then where does this unburnt fuel go when its modified does it go out the exhaust pipe
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    well if you ever have to have changes the swivel valv.. then they completly block the EGR, and change the programming of engine..
    Nov 2007
    Staffordshire
    Quote Originally Posted by neverlandandy View Post
    Yes. If fully blocked it will just take the least resistance route, Which is out the exhaust, If partially restricted, Then more Exhaust & less inlet Etc
    Dean
  1. Strange thing happened today?
    By ronnie63 in forum Engine & Drivetrain
    Last Post: 13th September 2012, 16:54
  2. What really dull thing have you done with the Vec today?
    By cont1204 in forum The 'Off Topic' room
    Last Post: 29th November 2010, 08:55
  3. the most usless thing i saw today
    By al21784 in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2008, 00:15
  4. Replies: 14
    Last Post: 30th December 2007, 14:40
  5. Radical new look!!!
    By Mrs D in forum Quick Photo Album
    Last Post: 26th July 2006, 18:40
