Thread: Machine Polishers
    Regular Member Led's Avatar
    Kings Langley
    Default Machine Polishers
    Is this any good eBay - 230246579316
    Looking to take a little strain out of the arms/shoulders with a Vec C, Vec B, Astra G & VW Beetle to clean.
    Your thoughts are greatly appreciated.
    Looks like a rotory, which is for the experianced user, you would be best with an orbital polisher ... Rotorys are easy to damage the paint with if you do not know what you are doing .
    cambs
    hi
    yep very good but get it from here
    http://www.transtools.co.uk/store/pr...r-2-heads.html
    also dont get the polishing mops get the meguiars from here
    http://www.cleanyourcar.co.uk/polish...ds/cat_23.html
    and these little ones from here
    http://www.cleanyourcar.co.uk/polish...ds/cat_19.html
    well worth it just tack your time and have fun
    cambs
    Quote Originally Posted by Bainie View Post
    he is right but
    if you dont go above speed 1 and dont stay in one spot (keep it moving) and keep a check on your work you should be fine and use a light cutting polish first till you get use to it.
    Kings Langley
    I have one of these
    but is not too brite - the foam pad comes un-stuck and the ramdom orbit doesn't always work.
    I was impressed at first - Before Pic (Daughters Corsa paintwork very dull and felt like 1000 grade wet'n'dry)
    The After Pic - (smooth as glass, deep shine with only basic products - Car Plan T-Cut & Simonoiz Demon Shne)
    Now that I have a large variety of Megs products - I was looking for a Polisher that lasts.
    Part of our fleet.
    Quote Originally Posted by mhvcbv View Post
    he is right but
    Keep a check on your work is ok, but you are not going to see anything until it is too late !! Really would not recommend a rotary for a beginner, an orbital is much safer, with the rotary you risk striking through, particularly on edges which will heat quciker and may be thinner .... Not worth the risk imo ..
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    Those vehicles certainly look good, a credit to the owners.
    I've thought about buying one of these poslishers myself in the past but always feared I would end up with swirly marks on paint work.
    cambs
    hi i understand your worries about damage to paintwork and a orbital are safer option for beginners.
    but as long as you dont go above speed 1 and use a soft mop with a very light polish you should not do any damage.
    most damaged is caused by exsesive pressure or holding it at an angle on the paint by trying to get quick fix but it all in the time taking.
    very slow and steady is the answer with all machine polishing and using the right polish and cutting compounds and good quality mops.
    but as you said the rotary is a bit more harsher then an orbital, so if in any doughts use an orbital one for the safer option.
    Regular Member baztheman's Avatar
    washington tyne & wear
    hi i got this type
    http://cgi.ebay.co.uk/Top-car-boat-p...742.m153.l1262
    this is mine though ( i couldnt wait so i bid in euros)
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=350045654588
    heres my astra which i had just polished
    http://forum.vectra-c.com/showthread.php?t=46518&page=3
  1. Want to use a diagnostic machine ? Or program a new key to your car ? Use my machine !
    By cyberbobdude in forum Vectra C / Signum Troubleshooting
    Last Post: 7th July 2012, 21:42
  2. any deals on polishers?
    By no1golfer in forum Detailing and Car Care Discussion
    Last Post: 15th December 2009, 13:22
  3. DA polishers?
    By hyperman in forum Detailing and Car Care Discussion
    Last Post: 21st June 2009, 21:41
  4. Electric Car Polishers?
    By Andy17899 in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2008, 09:07
  5. Rotary Polishers
    By Brocks in forum Detailing and Car Care Discussion
    Last Post: 25th June 2008, 09:42
