Thread: Yet another -- suspension crunches... :(
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    Default Yet another -- suspension crunches... :(
    I see there's a lot of threads about this. Most get it sorted in warranty I see.
    I'm out of warranty by 4 months, and my suspension sounds like a bag of spanners.
    Is it a costly fix, and what is it likely to be that needs replacing?
    Jul 2006
    Mexico
    I think 3 choices mate.....have you done the spring seat mod? if not thats probably it...cheap BTW
    On the other hand could be a broken not that cheap or anti role bushes...cheap.
    HTH
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    Ahh!... no I haven't done that spring seat on it, thanks for reminding me.
    Hopefully that'll do the trick
    Regular Member tankman's Avatar
    Feb 2007
    NORTHUMBERLAND
    what's the mod(springseat) guys sorry for the stupid question
    Regular Member JonV6's Avatar
    Cardiff
    Just had the front end apart in an attempt to find the cause of the ever present suspension knocking.....
    I've taken off the drop links and checked the anti-roll bar bushes and as silly as it sounds I was gutted to find nothing wrong!.....
    Springs are not broken, susp mod is fitted, drop links removed and checked for wear and anti-roll bar bushes inspected.....
    I was hoping to find some wear somewhere which would give me some hope in fixing the fault, but nothing.....
    My question to the guys that have changed their drop links and bushes and successfully cured the knocking is "how visible was the wear, or could you feel the wear in the components you changed?".....
    Portadown, N.I.
    Quote Originally Posted by JonV6 View Post
    When replaced my drop links and ARB bushes, the original ones while on the car looked fine with no play in the ARB that I could see/pry. But when removed the ARB bushes had a slightly oval hole instead of the proper round hole that the new ones have.
    Hope this helps,
    Tim
    Jul 2006
    Mexico
    Quote Originally Posted by tankman View Post
    ha! this will show you the light mate
    HTH
    http://forum.vectra-c.com/showthread...ghlight=spring
    Cardiff
    Thanks spuddevans, I figured this would probably be the case. I guess it takes nearly 2 tons of V6 diesel estate to show up the wear!
  1. V6 suspension
    By V6 Turbo Elite in forum Vectra C / Signum Car Chat
    Last Post: 3rd January 2012, 21:03
  2. Suspension knocking? Will Vec c suspension fit a Siggy?
    By shane5861 in forum Handling & Braking
    Last Post: 6th May 2011, 14:20
  3. DTi suspension v CDTi suspension
    By jamesy in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2011, 19:02
  4. What to do with my suspension?
    By jimmyred in forum Suspension, Wheels & Brakes
    Last Post: 15th February 2011, 15:11
  5. Replies: 5
    Last Post: 21st March 2010, 12:34
