Thread: Help required (non vectra)
    Regular Member Gr4eme's Avatar
    Feb 2007
    Durham
    Default Help required (non vectra)
    I have a peugeot expert van 1.9d over the last couple of days the engine has started making a rattling, knocking noise, but not all the time, when it happens it only lasts for about 1-2 seconds.
    I was wondering if its got a timing chain not belt and if its might be that or if it might be something like the oil pump
    Any help would be most welcome.
    Thanks, G.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    Quote Originally Posted by Gr4eme View Post
    Thanks, G.
    hi gr4eme these have timing belts and not to easy to get to as they are quite close to the inner wheel arch as to the knocking could be a stick shim which is located in the buckets under the camshaft hope you get it sorted m8
    Devon
    That'll be the crankshaft pulley which is also a crankshaft damper beginning to come apart. Eventually it falls off usually doing a bit of damage on the way!
    Get it checked and a new one fitted as soon as you can. I have heard that non-manuafacturer's replacements don't last long so probably best to go for a Pug/Citroen one. Can be pricey though. eBay sometimes has them for sale but check for manufacturer.
    Oct 2007
    Shropshire
    Is the knocking as you put you foot down, on the overun, or at tick-over?
    Feb 2007
    Durham
    can be at any time really, only happens a few times a day, its not there all the time.
  1. Vectra Advice required
    By Calamity Gian in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2008, 19:17
  2. Advise required on Vectra 2.0 DTi 2003
    By cp123 in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2006, 13:42
