Results 1 to 10 of 11
Thread: Mtec Help???
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    confused Mtec Help???
    I just bought a second hand Mtec HID lighting kit and i notice that the bulbs do not lock into place in the headlight. Not a huge problem as i have taped them in place with electrical tape.
    Does the bulb have to sit a certain way in the headlamp for the beam to be correct or does the projector lens align the beam no matter what way the bulb is positioned?
    Thanks in advance
    Keith
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    The original clip does hold the bulb in a certain way,hence the flat on the bulb,can't you use the original clip? or if not HIDS4U sell split clips to fit the vec.
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    The HIDS4U split clips are ok but they still need a fair bit of bending & shaping to make them fit - I don't know how much a pair of Vx clips cost but I reckon it would be easier to split the OE clips & refit them.
    Jan 2008
    Dundee
    so.... I can take the original clips off the loom and they should fit ok?
    I think i'm gonna have to remove the headlights to get more room.
    Will I need to remove the bumper to remove the headlights?
    The original clips should fit iirc ... and headlamp removal is a bumper off job, but it is easy, a how 2 somewhere on the site ..
    Mar 2007
    Southport
    Mine is a pre f/l & I didn't remove the headlights, just the airbox.
    You should be able to use the OE clips - if the bulbs are permanently wired as are those from HIDS4U you'll need to split the clip on one side otherwise just slide them over the bulb.
    Jan 2008
    Dundee
    yes i catch your drift mate my bulbs are permanently wired. i'll have a look at them again when i get a spare minute. I think my way of using electrical tape to keep the bulbs in place is a bit rough lol
    Mar 2007
    Southport
    These are the HIDS4U bulb holders
    Jan 2008
    Dundee
    ok thanks for that. they are a bit pricey for what they are. i'll try using my old ones first
    Mar 2007
    Southport
    They come as part of the kit otherwise I would've modified the original or bought Vx repacements - I think I'd cut the originals & then try to superglue a bit of feeler guage over the gap to make them more rigid again as they take a fair bit of hammer twisting them into place
  1. MTEC 501s in MOT?
    By 19CDTi in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2012, 17:25
  2. Mtec H3
    By hothatch in forum Electrical & ICE (including SatNav)
    Last Post: 25th November 2011, 20:01
  3. Mtec sidelights
    By Dazzy2006 in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2011, 01:44
  4. mtec kit
    By billyyoung in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 14th April 2008, 19:52
