Results 1 to 10 of 13
Thread: 1st gear...
    Regular Member djr69uk's Avatar
    Midlands
    Default 1st gear...
    ... sometimes fights against me when the car is cold. Onced warmed up it's fine. Just not as easy to get into until I've done a few miles. 72k 55 plate cdti150.
    Not causing major issues but just thinking ahead. Thinking synchros... what they like on veccy gearboxes? Also what are the gearbox oil service intervals? Might get that changed to see if it's a lubrication problem!
    Full Member Big Sig's Avatar
    There is no service point forthe gearbox oil, but it can be changed if you wish. Mines the same when its cold. I think most will be tbh. Not too sure if it has a syncro on first gear?
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Fully synchromesh, even reverse as far as I know but the 6 speed is not a pleasant gearbox to use particularly when cold
    Regular Member GoldenWonder's Avatar
    Durham
    I find my CDTI 120 gearbox one of the worst parts of the car. Its stiff and awkward when cold. When its warmed up its a bit better but even then a quick change from 1st to 2nd will cause a crunch and some resistance.
    From I read on here its just the way they are! I remember my old Omega having a pretty 'clunky' gearchange as well - its one area where I think Ford do it better.
    Feb 2006
    Guttedsville
    Yep, a feature of mine also. When the gearbox is cold, the gears in the left hand plane can be a nightmare to select.
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    Mines the same. better when warm. I had a Vectra B before and that was a bit funny from 1st to 2nd. Before that my Mk2 Cavalier had a lovely gearchange!
    Regular Member bill1250's Avatar
    Apr 2008
    Hampshire, England
    Mines not to bad on a 1.9 cdti, sometimes when i go to second it sticks abit and same to fourth ****es me off but doesnt really happen often
    Leeds
    Just been doing a search for "gearchange" cos' I've got to agree, just bought an 08' plate Vectra CDTi SRi 150 and the gearchange from 1st to 2nd when cold was a real surprise. Come from driving a Ford Puma with it's ultra slick gearchange and the Vectra felt like a tractor! I'm used to it now & agree that it's worst when cold so just take a steady for a few miles and when it's warmed up it's much better.
    J.
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    First to second on my 1.8 pre-facelift is so bad when cold that I have dropped into the habit of "doubling the clutch" to overcome this. I thought that I had left this behind with my 1950 gearboxes!!!
    Regular Member mat100edt's Avatar
    south coast
    i have 6 speed in my 100edt, not sure if its same box but it is a bit naff when cold!! not the best of gearboxes when warmed up either to b honest!!
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2017, 03:14
  2. Gear lever,gear selector
    By jodiexii in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2013, 09:43
  3. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  4. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  5. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
