Thread: Door Switches
    Apr 2006
    Ash, Nr Aldershot
    Default Door Switches
    Both the door/window switch units on our Vec are playing up, it take several stabs to get the windows to go up or down. I have read somewhere on the forum that spraying the switches with a contact cleaning spray cures this fault. Can anyone recommend a spray to use and also how these switches are removed from the door.
    Jul 2006
    Mexico
    You may also want to check that you have a good connection at the plug mate
    To remove the switch I think you have to remove the door cards...somebody will confirm this..
    HTH
    Surrey
    You can carefully prise the switches out.
    Regular Member NealM's Avatar
    Mar 2007
    Cheshire
    Vehicle : Pre-Facelift
    Trim : LS
    Engine : 1.8 Petrol
    Hi
    I had exactly the same problem.
    If you use a small flat bladed screwdriver at the bottom of the switch you can prise it out of the door card.
    Once it's out you have to disconnect the wires. On the drivers side there is a small lever which you pull up and it disconnects the wires. On the passenger side it was just a simple push / pull fit.
    There are then just a couple of screws holding the switch assembly together. Undo them and then the switch can be levered apart.
    I just squirted a little bit of WD40 on mine and then reassembled.
    They've worked perfectly ever since.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    My pass side did the same.
    Dismantled the switch and cleaned the contacts and all is good again.
  1. Passenger door switches
    By brianjamesreed in forum Electrical & ICE (including SatNav)
    Last Post: 12th April 2012, 19:57
  2. what smd's for the door switches?
    By Morephun in forum Electrical & ICE (including SatNav)
    Last Post: 25th January 2011, 14:58
  3. No lights on door switches?
    By lencuff in forum Electrical & ICE (including SatNav)
    Last Post: 28th October 2010, 18:40
  4. Facelift Door Switches
    By cameraman in forum Parts for sale
    Last Post: 9th May 2009, 11:09
  5. Set of door switches...ALL doors..
    By armoured farmer in forum Parts for sale
    Last Post: 30th April 2007, 18:39
