Thread: nokia n95 8gb
    Regular Member The Gas Man's Avatar
    Feb 2006
    north east
    Default nokia n95 8gb
    now then, i have a nokia n95 8gb and am having real problems installing garmin xt onto the phone , or any other third party sat nav ! i can install all of the sat nav , but garmin will not recognise the phone as a gps reciever ? any help would be greatly appreciated , pm's welcome thanks
    Regular Member sparky71a's Avatar
    Apr 2006
    At the Garage
    If you use a third party nav software,you'll have to use a bluetooth nav receiver. The internal Nokia receiver will only work with Nokia Maps....
    N. Ireland
    1. unzip the download and install the file called garmin onto your memory card.
    2. Disconnect phone from pc then navigate to the garmin folder and run the garminxt.sis this will install the aplication.
    3. when installed goto aplications folder and start garminxt.
    4. open settings open about about
    3. Make note of your "Card ID"
    4. Launch the keygen, and enter the "Card ID" you see on GMXT About page.
    5. hit generate code
    5. Copy (CTRL+C) the Device unlock key to clipboard.
    6. Now open Notepad and paste (CTRL+V) the key and save the file as SW.UNL
    9. Put your newly created file to your SD Card\Garmin directory and restart GMXT.
    8. Program should now recognize your built-in GPS (if not go to settings\system and choose "connected gps") and you should be
    able to use detailed maps.
    N. Ireland
    Quote Originally Posted by sparky71a View Post
    Not true! internal gps working on mine with garmin
    Regular Member cornishpirate's Avatar
    Cornwall
    Works on mine too.
    If you google sat nav on n95 you can find a number of free access forunms with info about this application on an N95
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    88 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    I have Garmin XT installed on my N95 aswell and it uses the internal GPS, you just need the correct version number, Garmin released an update to work with the internal gps.. I also have other gps software installed on it that uses the internal gps, The other programs are:- Amaze, GSM Trckr, GSM Navigator, AFtrack & MGMaps... route66 also works with the internal gps aswell... i've had to look into gps on the N95 for work as they wanted to be able to track our engineers...
    Lots of other good mobile and pda software to buy or try on www.handango.com
  1. nokia n96
    By stuart bigboy in forum General items for sale
    Last Post: 4th October 2009, 10:11
  2. Nokia CK-7W
    By amiddleton in forum Electrical & ICE (including SatNav)
    Last Post: 7th March 2009, 22:58
  3. nokia n80
    Last Post: 9th January 2008, 23:56
  4. Nokia N70
    By R13hard in forum General items for sale
    Last Post: 5th March 2007, 15:21
