Results 1 to 10 of 13
Thread: Elm 327 Code Reader, Anyone!!!!!
    norfolk
    Question Elm 327 Code Reader, Anyone!!!!!
    Hi All, Has Anyone Here Used This Elm 327 Code Reader Via Laptop/pc, On There Vectra C ? Did It Work Ok Or Not? As I Am Thinking Of Buying One, Cheers.
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    I have one.. it does read the engine data ok. Not sure about reseting codes as I've not had any that have needed doing.
    Want to buy it?
    Regular Member 30ltr nutter's Avatar
    dunstable
    hi the elm 327 reader works on vectra c i have a 30cdti and it reads limited date but it does read and clear fault codes i have one and the spanner light came on on sunday i hade checked the car and found turbo pipe had come off . so i checked with reader just to c if it worked ok and it give the relavant fault code and cleared it after the repair i hope this helps
    norfolk
    ok cheers, would you mind telling me which pins you have in your car obd11 plug, as i dont have pin7 or 15, which i believe it needs to have?.
    Feb 2007
    Glasgow
    You don't need pins 7 and 15, that's the K and L lines that were used by the older protocols. Vectra C's use CAN Bus, think it's pins 6 and 14 for HSCAN.
    Regular Member hans_vledder's Avatar
    't Veld - The Netherlands
    Quote Originally Posted by shunter View Post
    Is this the case for a Vectra C of 2002 too? I have an ELM327 (scantools) here, but I don't seem to be able to get this thing going. From the laptop to the interface everything works, but it does not seem to be able to figure out the protocol used. What OBD standard does Vectra C 2002 offer?
    TIA,
    Hans
    Feb 2007
    Glasgow
    All Vectra C's are CAN bus. Petrol models are OBDII compliant from 2002, but some diesels are from 2004 onwards, and that might be why you are having problems.
    Hi shunter,
    Thanks for your help. So I my 2002 diesel is probably just OBD-I compliant. Is there any way to put an ELM327 reader into ODB-I mode?
    Regards,
    Hans
    Regular Member ccsnet's Avatar
    The local dealers if driving my old Vectra
    The ELM 1.2a is Canbus complient and I'll be getting one soon along with a right angle cable..... it also works with Centrafuse which will display the fault code & allow a reset too...
    Watch my web site because I'm in the final stages of my build which is why I have not been on here for ages.
    Terran
    @home
    Engine : 1.9 CDTi
    Quote Originally Posted by ccsnet View Post
    Terran
    Terran, will this cable allow you to close the ashtray lid?
  1. Code reader
    By phil0464 in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2012, 22:05
  2. Birmingham - Code reader / live data reader
    By awilson1234 in forum Engine & Drivetrain
    Last Post: 26th September 2011, 16:55
  3. Code Reader
    By Paddy in forum Engine & Drivetrain
    Last Post: 4th April 2011, 21:21
  4. Code reader
    By Paddy in forum Vectra C / Signum Car Chat
    Last Post: 27th March 2011, 18:21
  5. code reader
    By stevie in forum Engine & Drivetrain
    Last Post: 11th April 2008, 20:48
