Results 1 to 10 of 14
Thread: whoops....when changed pads
    Regular Member Craig1985's Avatar
    harwich essex
    Eek whoops....when changed pads
    the stealers have changed my pads before and i done them a second time,
    but when i done them, i opened fluid res and pused piston back slowly without undoing bleed nipple? is this wrong have i fooked up my m/c?
    ive now read threads where people saying this is what you have to do? whoops?
    my brakes certainly dont feel as sharp and hard as when car was brand new?
    help
    unless you were aggressive when you pushed back the pistons you'll be fine..they will need about 200 miles to fully bed into the discs, so you must brake early and carefully.. they will get better....
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    i have never opened the bleed nipple to push back the piston is this wrong? also to bleed the system is it better 4 the car to be on or off?
    Somewhere I probably shouldn't be
    For a full proper bleed, the ABS needs to be activated, this can only be done by the dealer (or someone with a TECH2 - I think it's controlled by the TECH2). Air can get caught up in the ABS actuator and the only way to get the air out is by bleeding it with the ABS actuator on.
    Aug 2007
    Lisburn, N.Ireland
    well i am changin my calipers soon so have a brake line clamp thing which my friend has use no problem so i only need to bleed a little i.e. the end ot the hose just to fill the caliper so will i still be ok to do this with out the abs on?
    Regular Member Ian's Avatar
    York
    Yep no probs with that, just make sure that the resevoir is kept topped up, therefore no air can possibly get to any important bits.
    Regular Member amar's Avatar
    London
    When replacing brake pads all that is required is that the brake fluid reservior cap be removed thus allowing the brake fluid to rise up when the piston is pushed back. this will not allow any air into the system.
    with respect to replacing the callipers, as mentioned before so long as the reservior does not become empty when bleeding the brakes all is well.
    the abs system can be bled without switching the car on, it just takes some time. you are advised to always start furthest away ie passengerside rear wheel, then drivers side rear, then passengerside front and finally drivers side front. when bleeding the brakes if you look at the colour of the fluid it will become apparent when the new clean fuild comes thorugh, once it is coming through clean at the first point then lock it up and move on to the next.
    when i did mine i used between 1-2 litres of brake fluid so that i was sure the fluid was new all round and throughout the system.
    hope this helps...
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    What're the opinions on the Eezi-Bleed Pressure System??
    Sunny Dartmoor
    Used one years back and thought they were great,would definately use one again if i had the money to buy one,they're a tad expensive,iirc..........
    Nicking Ya Dinner.
    Did you do the rear pads? if so you should use a winder rather than just push them back.
    If it is the rears, you might get away with refitting the old pads and pumping the pistons back out, then use the winder to push them back and put the new pads back in, it's a 21mm winder you need.
  1. Changed Front Brake Pads
    Last Post: 21st January 2012, 18:21
  2. Changed front pads now no brakes
    By Signum150 in forum Suspension, Wheels & Brakes
    Last Post: 6th June 2010, 17:14
  3. changed pads, grinding noise!?
    By mattster87 in forum Handling & Braking
    Last Post: 16th May 2010, 20:13
  4. Changed front pads today...
    By hagga in forum Suspension, Wheels & Brakes
    Last Post: 15th May 2007, 12:54
  5. Brake pads and discs changed
    By bruceybonus in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2007, 23:10
