Thread: How much meat in brakes?
    Jul 2006
    Mexico
    Default How much meat in brakes?
    The brake meat warning sign is on now and I took a peek without removing the front tires and seem to have 1/8 of an inch on the right side and something like half an inch on the left.
    Is this a fault in the sensor? How thin are pads when the sensor triggers?.
    Thanks chaps
    There is now only one sensor and I believe it is on the offside
    However, if your break pad wear is as you suggest then there may be a sticking piston that requires attention
    I can take my brakes right down to indicator and both are pretty much equally worn
    the sensor comes on when there is about 3mm ( just under an 1/8" ) left on the pads...
    if the sensor has tripped then it'll need replacing as well..
    Regular Member eaglepva's Avatar
    Up North
    Where do you get a replacment sensor from?
    UK
    Not sure if you can get it from anywhere else but I got mine from the dealers at a wopping 10 quid.
    Sunny Dartmoor
    Jul 2006
    Mexico
    Thanks for the advice mate...I`ll check exactly how much meat by taking off the tyres and have a better look.
    Thanks Mark...I think its time for new pads, and yeah a new sensor...anyway as far as I know they usually brake when replacing the pads so...
    Quote Originally Posted by eaglepva View Post
    Stealer's mate...not to expensive as mentioned above
    Regular Member tankman's Avatar
    Feb 2007
    NORTHUMBERLAND
    you can get the sensor wire from the stealers they cost around £20 rip off mate
  1. Replies: 14
    Last Post: 3rd September 2011, 20:23
  2. Pepsi and raw meat...
    By ade0303 in forum Comedy & Humour
    Last Post: 16th October 2009, 21:28
  3. who`s got the 314 brakes??????
    By VEC-MAN in forum Vectra C / Signum Car Chat
    Last Post: 7th October 2009, 19:18
  4. I am The Meat!
    By AJA in forum Comedy & Humour
    Last Post: 20th July 2009, 20:17
