Thread: ****** Brakes!
    Regular Member kev bux's Avatar
    Jan 2006
    BOROUGHPETER
    Default ****** Brakes!
    hi all,
    help help help.
    front brakes - they work fine but some days they sound like the brake pads aint got any meat on em.
    wots going on?
    i fitted new front discs and pads from dealers about 3 months ago.
    the sound is hard to explain.
    i have done a test down a quiet road and the abs comes on ok and they pull me up no problem.
    cheers.
    kev bux.
    Sunny Dartmoor
    I had the same sound when i first got my car kev,remove all pads and thoroughly clean the calipers, carrier's and remove the lip off the pads,reassembled using copper grease sparingly,should sort it out mate......
    Let us know how you get on............
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Is this noise apparent after the car has stood over night Etc ??
    If so it could be the damp in the atmosphere creating a film of rust/oxidisation on the discs & the metal content within the friction material on the pads, Mine does this in a morning for the first few presses, especially when it has been damp Etc.
    Dean
    Regular Member poves's Avatar
    lancashire
    If you av used copper slip that rules that out , have u checked the shim (guard plates) aint rubbin on the rear of the discs at the bottom ?
    Worth checkin.
    Jan 2006
    BOROUGHPETER
    ok, cheers lads.
    i will have a look at them at weekend, not doing it all the time. i put some copper grease on the back of the front pads about a month ago and that stopped the squeaking but that has also reappeared.
    i will keep you all posted.
    thanks again.
    Regular Member Big Davie's Avatar
    Jan 2006
    having a giggle...
    I had the same problem too mate, I've already posted in this thread as I saw it first...
    http://www.vectra-c.com/forum/showthread.php?t=46522
    HTH's.
    Jan 2006
    BOROUGHPETER
    ok,
    had time after work to have a look. removed the calipers and re copper greased the back of the pads and everything else that was mentioned in the previous replys. put it all back together and went out for a test run.
    feels and sounds ok but need to potter around town in the car were there will be a lot of pulling away and pulling up to get them warm cos the sound i described seems to only appear this way.
    will see how i get on. cheers lads.
    Sunny Dartmoor
    Hope its sorted kev......
  1. Replies: 14
    Last Post: 3rd September 2011, 20:23
  2. Brakes
    By Si-SRI in forum Suspension, Wheels & Brakes
    Last Post: 27th February 2011, 10:21
  3. my brakes
    By bigron1988 in forum Handling & Braking
    Last Post: 27th November 2008, 08:03
  4. Big brakes on my GSI?
    Last Post: 7th May 2007, 21:07
