Thread: mud flaps can they be removed ?
    Regular Member STAV's Avatar
    Oct 2006
    tyne & wear hebburn
    Default mud flaps can they be removed ?
    just wondering if anyone knows how to remove the mudflaps from a veccy sri these are the ones that have the torox screws underneath but have those fittings into the side which have to be placed in the holes then hit with a hammer to push fit the pin to expand the other side ( wish i knew the name), anyway other that knacking these is there a way to remove them if not can these be bought from vx ? as im wanting to remove to paint them .
    Oct 2006
    tyne & wear hebburn
    push fit rivet thats the name , can these be bought from vx ?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Probably, or any hardware store.
    If you can get access to the rear of the rivet, just push the centre pin out and remove the rivet.
    If you can't, then (depending on size) drill a small hole in the pin, screw in a small screw and pull the pin out with pliers.
    Oct 2006
    tyne & wear hebburn
    cheers mate but carnt get at the back of them and they are two small to drill, looks like its a hackem off and bodge job.
    [Ex]Admin Duncan's Avatar
    You can just push the centre pin right into the 'rivet' and that will let you get them out. The centre-pin will just fall into the void behind. I'm not familiar with where the mudflaps actually attach to, so the pin will either be retrievable and so the rivet can be reused, or it will just fall into the void and remain there, or fall out whilst driving. Vx sell replacements and are fairly cheap.
    Oct 2006
    tyne & wear hebburn
    cheers duncan mate
  1. Have you removed your dpf or not
    By winnie2457 in forum Diesel Engine related
    Last Post: 27th January 2013, 20:55
  2. dpf removed
    By figo1805 in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2012, 16:59
  3. removed?
    By treasure22 in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2010, 11:06
  4. Should i get it removed
    By Hyperhart in forum Vectra C / Signum Car Chat
    Last Post: 12th April 2010, 23:04
