Thread: Any help? highly appreciated.
    Perth
    Default Any help? highly appreciated.
    My vectra Jul 2003 2198CC Petrol sedan is gone crazy. Firstly it went in limp mode a couple of months back and servicing found the Catalytic Converter is in pieces and glowing red hot. Replaced it with new CAT starts good but after a while went into limp mode again, servcing thought it might be the Head or the Gaskit but all fine then found the secondary oxy sensor is molten due to excess temperature in CAT replaced the oxy sensor. All runs good when start but after a while the Car went into the limp mode again and the CAT is still glowing, even the mechanic cannot find the issue with the car. He has done all tests and gone through all the readings, any help I'll highly apprecite.
    Thanks in advance.
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Hi, Might be worth a PM to Mark 3.2gsi.. I assume your mechanic has checked for any fault codes??
    Perth
    Default what is PM to mark 3.5 GSI ?
    Yes he has done all the fault codes but everything comes OK, and the guy is a dealership technician.
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Engine : 3.0 TDV6
    Mileage : 3023
    PM = Private Message, If you send a PM to mark he may be able to help, his username on here is Gsi3.2
    Somewhere I probably shouldn't be
    For some reason it seems like your car is burning too hot, this is usually due to it running very lean which can cause piston melt down.
  1. For Sale: Vectra VXR - Highly modified
    By spoons in forum Cars for sale
    Last Post: 7th August 2012, 12:51
  2. any help appreciated....................
    By coopey in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2011, 18:10
  3. highly wanted item
    By farley2708 in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2011, 15:59
  4. Insignia scores highly in American crash test.
    By Kowalski in forum Insignia car chat
    Last Post: 12th September 2010, 15:32
  5. Would HIGHLY recommend OEM Pads
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 17th September 2008, 09:54
vectra c catalytic converter red hot
