Results 1 to 10 of 22
Thread: Oops... Beginner's Mistake...
    Jul 2006
    Red face Oops... Beginner's Mistake...
    Think I've discovered tonight why my MPG has been so much lower than it should be
    Quiet night at work, which is fairly unusual, so thought I'd give the car a quick once over. I'm happy to hold my hands up and say I place too much faith in the car's warnings, and don't usually bother checking oil, water etc. So I've checked all the fluids and thought I'd have a look at the tyres.
    When I had these alloys fitted, they inflated them with Nitrous Oxide. This is becoming increasingly popular because the tyre rubber is less porous to Nitrous Oxide than to Oxygen, so in theory tyre pressure should stay constant for longer. It's been a few months now and to be fair, this is the first time I've checked the pressures myself!
    Anyway - trawled through the owner's handbook to find the charts for tyre pressures. It says: Z19DTH (check) estate (check) 235/35/29 tyres (check) should be 39psi (front) 35psi (rear).
    Now I know the rule of thumb for tyre pressures is twice the rim size, and they were fitted at Demon Tweeks, a large and experienced company, so I was expecting all 4 tyres to be 38ish... Imagine my suprise when I found all 4 tyres at 28psi!!! That's not only wrong, it's dangerous!
    So, having now inflated all tyres to the right pressure, I'm hoping my MPG should increase noticeably from the 'almost 40' I've been getting recently.
    Lesson learnt - check tyre pressures more often!
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    [quote=parapaul;563328]
    quote]
    The tyre must cost a fookin furtune at that size !!!
    Smacked wrists all round me thinks Paul .................Oh and i think you mean NITROGEN not nitrous !!!!!!!
    Regular Member signum junkie's Avatar
    Edinburgh
    Jul 2006
    Oh, gosh darn it being so late at night..... Or is that early in the morning?
    Yes, I meant Nitrogen... Nitrous is the stuff we give ladies in labour and wussy footballers with twisted ankles
    And what's wrong with my imaginary 29" tyres, Fil? I did, of course, mean 235/35/19...
    Regular Member shan's Avatar
    Good job you never filled the 19" tyre's to 29" pressure rating's.
    If not a big BANG you might have floated away
    Sunny Dartmoor
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    IMO you won't notice a huge difference in MPG if the tyres were filled to 28PSI.
    At 28 they're not flat enough to make it dangerous either.
    Also, IMO filling with nitrogen isn't going to make a huge difference either. The normal air at the compressor is 78% BV nitrogen anyway, and Nitrogen is a smaller molecule than Oxygen, so I can't see how tyres are going to be more porous to O2 as opposed to N2 anyway.
    Just applying logic to the puzzle, and to me it doesn't add up. N2 would be slightly lighter than O2 though, and at 2 bar pressure the gas will be only slightly lighter. Maybe the dry N2 is the key, as opposed to 'wet' air from the compressor. - 'Wet' air as it will contain water vapour.
    Density of N2 at 0C, 1 atm and dry is 1.251 g/L
    Density of air at 0C, 1 atm and dry is 1.275 g/L
    So DRY gases would not make a huge difference at all.
    Jan 2006
    carlisle
    Default tyre pressures
    in my handbook, for the 235/35/19 on a 1.9dth, it lists the tyre pressures at 44 front 39 rear
    Leicester
    I don't know the physics, but I know Nitrogen is better than compressed air in tyres.
    I did the same with my Astra, on 18" wheels, when the tyres were swapped over, 28psi was put in, should be 39psi fromt and 36psi back.
    Once at the correct pressures, mpg was for sure better, so Parapaul you should see an improvement
  1. Will this be a big mistake??
    By wilky3720 in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2012, 22:59
  2. Big oops or small oops? infor needed
    By davidmcd2002 in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2011, 17:44
  3. oops spelling mistake on sign
    By Deztroyer in forum Comedy & Humour
    Last Post: 23rd May 2009, 17:30
  4. lmf mistake -oops
    By Deztroyer in forum Tuning
    Last Post: 24th April 2009, 17:49
  5. What a mistake!
    By Brocks in forum Detailing and Car Care Discussion
    Last Post: 3rd May 2007, 19:30
