Thread: Boot lock failure
    Sunny Dartmoor
    Default Boot lock failure
    Had a problem with the veccy today,finished cleaning the rear window and shut the boot and it didn't latch in.....
    So opened locks,and locked a few time's to see if it would work,no way was it going to happen,by this time thought ****,what do i do.......
    Got on here and checked for previous posts and found a trick another member has used,did'nt work,so pulled off rear panel to have a look,never had to do this before and knew it was going to be tricky,spotted the solenoid and lock mechanism and tapped it and heard a movement,tried the lock and it worked....
    Sprayed the mechanism liberly with some GT85 and locked and unlocked it about a dozen time's,worked a treat
    Would like to say a big thank you to all who helps out and passes on info for all to use,again this site saved me a trip to the dealer and out of the **** with SWMBO,thanks again......
    Regular Member Colin S's Avatar
    Aug 2007
    Redcar
    Vehicle : Insignia VxLine
    Trim : SRi Vx Line Nav ST
    Engine : 2.0 170BHP
    Year : 2015
    Are you going to replace the internal parts in case it goes up the wall again at some unfortunate time which is sods law!!!.
    I was wondering why the mechanism would stick,its not as though it is exposed to the elements, the mechanism is buried within the boot lid and that is resonably well sealed? just wondering!!!
    Colin
    Sunny Dartmoor
    Not quite sure what i'm going to do,will leave it for now and see what happens,had the car nearly a year and its the first fault i've had.....
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    at least you didn't have to remove half your boot like Spoons
    Regular Member kpf1grandprix's Avatar
    luton beds
    strange thing is ,,when i bought mine the boot button was the 1 thing i said to my missus i was worried about packing in later on,,,,
    Sunny Dartmoor
    Was a bit scarey,thought to myself what happens if it fails with the boot closed,but found a removable plug in the rear panel where you can open the lock manually..........
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    ours always play's up whenever i wash the car or when ever it is wet in general, very nearly put my f-in hand through the rear window yesterday because it was playing up
    dealer's cant find a problem
    Midlands Mod Shop - NFFC.
    Regular Member BigLad's Avatar
    Feb 2007
    30,000ft by day, bed at night
    Yep hadthis as well although dealer fixed it under warranty
  1. Boot Lock no whirring noise and wont lock or open
    By meridianghost in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2012, 14:16
  2. Boot Lock
    By alancallaway in forum Electrical & ICE (including SatNav)
    Last Post: 23rd June 2012, 18:35
  3. Boot lock failure
    By Justelis in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2010, 15:55
  4. boot lock
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2007, 22:58
  5. boot key lock
    By selv1980 in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2007, 07:31
