Thread: fitted egr valve
    Regular Member littlesxi's Avatar
    Oct 2007
    derby
    Default fitted egr valve
    fitted my new egr valve yesterday (thanks kevwh) after having the codes read and it coming up faulty,anyway put the new one in and it has made no difference at all (still in limp mode) do i need to have it tech 2`d to clear the codes/limp mode?
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    glad you got one mate, what is the fault code as it could be something to do with the swirl valve or an injector, have read this in other thread's
    Midlands Mod Shop - NFFC.
    Regular Member baztheman's Avatar
    washington tyne & wear
    dont trow your old egr valve out m8,you can buy egr cleaner and check the solnoid for corrosion.
    i know you said it made no difference changing it but did you use a new seal ?
    put your fault codes on here and im sure someone will help you sort it out... baz
    Oct 2007
    derby
    bump original question
    South Central England
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Don't know for sure but with all faults I have come across the ECU checks on start up and if no fault found it starts normally and just keeps the fault stored. So I think you may have another problem unfortunatly You'll have to get the codes read and see if there is anything else.
  1. dump valve fitted eml on
    By tomo41 in forum Engine & Drivetrain
    Last Post: 5th August 2011, 21:45
  2. New EGR valve fitted !!
    By renton608 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2011, 20:50
  3. How much to get a new valve fitted on a tyre.
    By connery-sri in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2010, 12:52
  4. Brand New EGR Valve Fitted and.....
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 8th August 2009, 22:22
  5. New EGR valve £305 fitted!!!! 1.9CDTi
    By installer in forum Vectra C / Signum Car Chat
    Last Post: 21st May 2008, 22:22
