Thread: Automatic headlamp range adjustment fault!
    Jan 2008
    Hope Valley, Derbyshire
    Default Automatic headlamp range adjustment fault!
    Hello
    My 2003 Vectra has got the above warning light permanently on the display which suggests there is a fault. Any ideas??
    Many thanks, David.
    Regular Member Stu14t's Avatar
    Perth, Scotland
    Take it you have xenons.
    May be the sensor on the suspension I should get a tech2 on it to see the fault codes. Last thing you want to be doing is dazzling other drivers.
    Jan 2008
    Yes it has Xenons but not on full beam. They doesn't appear to be anything wrong with the way they work. Will have tto get them checked out.
    Cheers mate.
    Perth, Scotland
    No, the lights themselves will work as normal. However, there is a sensor on the rear suspension that automatically adjusts the beam level. It may be that or one of the adjuster motors is not working.
    Some people have had issues with water ingress into the headlights that can corrode the electrics in there and cause problems
    Jan 2008
    Thanks for the info, will have to have it looked at. Hope it doesn't cost too much money! Usually do my own repairs etc but with things like this, I haven't got a clue.
    Regards, David.
    Regular Member voodoo77's Avatar
    Jan 2008
    Romania
    Hello,
    I have the same problem with that sensor. I've been already to a service and they found some problems to my lights system, solved it and also they reset the fault codes. But now it happens again and they said to me it's the sensor.
    What it's the sensor name or id and what will be the right price for it ?
    Can I change it myself or should I take the car to a pro (service) ?
    Thanks.
  1. Heaglight Range Adjustment
    By smoggie in forum Electrical & ICE (including SatNav)
    Last Post: 10th January 2013, 02:37
  2. RHD to LHD headlamp adjustment
    By John LE in forum Electrical & ICE (including SatNav)
    Last Post: 3rd November 2010, 09:55
  3. Headlamp adjustment message after lowering
    By Harro in forum Suspension, Wheels & Brakes
    Last Post: 3rd April 2010, 18:28
  4. Headlamp beam adjustment for europe
    By goonturbo in forum Electrical & ICE (including SatNav)
    Last Post: 29th March 2009, 20:49
  5. AFL Headlamp adjustment?
    By Matty H in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2008, 01:36
