Results 1 to 10 of 13
Thread: rear top suspension arms
    Apr 2008
    SOMERSET
    Red face rear top suspension arms
    Hi Ya, First Time Here So Bear With Me, Looks Good So Far
    I Have A 1.9cdti Sri Whitch I Think Needs New Rear Top Arms,
    Had A Look From Underneath Today And The Inner Bolts Are Nearly Impossible To See. Yet I See On Here People Are Saying Only About An Hour And Is Easy To Do. Is It Better From Underneath Or From In The Side Behind The Wheel If You See What I Mean, And Has Any One Replaced Just The Bushes !!
    Also Excuse My Ignorance But Why Is There A Lot Of Talk About Egr Valves (what Do I Need Look Out For)
    Sunny Dartmoor
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    not sure about the top arm's but as for the egr, just type it into the search bit on the forum and you will see what all the fuss is about, and btw to the site
    Midlands Mod Shop - NFFC.
    Regular Member Jay Kay 313's Avatar
    Burgess Hill
    to the site matey & enjoy
    The rear arm's are not to bad to do little bit fiddily to get to the inner bolts and you can do them in an a hour or so. No you can't just change the bush's like the old vec B's it is the whole arm that you will have to replace witch is a shame. hth
    Jan 2006
    Skynet HQ EMEC#5
    to the site
    I did my rear upper arms, took about an hour each side. Jacked up car, sat on axle stands & remove wheel. then you will be able to get at the bolts easier. The inner one will be easier to get at using an extension.
    When you fit the new arms, I found it easier to put the inner bolt in first.
    Regular Member Dodger's Avatar
    West Midlands
    to the site Brian, enjoy
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    hi m8 and to vectra-c hope you get it sorted
    Apr 2008
    SOMERSET
    Thumbs up
    hi and thanks for the help
    how do i use the search for egr !!!!!!!!!1
    Regular Member JOHNBOY's Avatar
    Vx-Outlaws
    12 Post(s)
    Vehicle : 2008 SILVER LIGHTING VEC VXR, 2002 VEC B C20LET , 2012 VX COMBO, 2014 GOLF GTD
    Trim : .....
    Engine : ....
    Year : ....
    Regular Member moles-sri's Avatar
    Jan 2008
    south wales
  1. rear suspension arms
    By les287 in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2012, 18:46
  2. rear upper suspension arms.
    By john1 in forum Suspension, Wheels & Brakes
    Last Post: 27th May 2011, 12:52
  3. rear top suspension arms
    By glynn in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2009, 23:02
  4. rear top suspension arms
    By BRIANE in forum Suspension, Wheels & Brakes
    Last Post: 3rd February 2009, 21:34
  5. Changed the rear suspension arms yesterday
    By monkeez in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2009, 12:07
