Thread: Brake Light Warning
    Regular Member DarrenLee's Avatar
    Shipley, West Yorkshire
    Default Brake Light Warning
    Hey Guys n Gals
    Got in the car this morning and on the display unit it said BRAKE LIGHT. I presumed it was telling me I needed a new brake light so gave the wife a shout to come out and press the brake light while I checked
    BUT
    They all worked - nice and bright - no obvious differences or changes
    Any ideas / this happened to anyone else??
    11 Post(s)
    The rear brake bulb is shared with one of the 2 tail lights. If the upper bulb goes, then the lower one takes over as the tail / brake light.
    Take the rear light clusters out and visually inspect that each bulb is working. Could be that the upper tail /brake bulb has failed and the lower one has taken over.
    Bulbs from top to bottom:
    Turn signal light
    Tail light / brake light
    Tail light
    Fog tail light (works on drivers side only - this is normal for the UK)
    Reversing light
    All bulbs are 21 watt.
    Regular Member Maddog1974's Avatar
    Jul 2006
    Colchester
    Also i had 2 of the led's in the boot brake light fail intermittantly and that caused the warning light to come on took ages to notice why!
    Bournemouth
    Where are you guys getting replacement bulbs from?
    reason I ask is that according to Halfords, I need a 381 type bulb. The ones they sell have two filaments whereas the GM lower rear tail light I think has only one, fitting a Halfords 381 bulb in the lower rear tail position sees the less bright filament being used and results in it looking as if its not on... also the bayonet fixings on these bulbs are at different heights whereas standard fit GM bulbs have them at the same height...
    help?
    11 Post(s)
    Quote Originally Posted by Agoogy View Post
    All the bulbs in the rear clusters only have one filament, that being a 12 volt 21 watt bulb. For the tail light a reduced voltage is supplied to the bulb (to make it dimmer) and when it becomes a brake light the voltage is increased to make it brighter.
    See my post further up for info/layout of the bulbs in the rear clusters.
    Bournemouth
    Thanks Dave,
    Does that make Halfords 'bulb giude' utter rubbish then?...
    I'll be popping in there at lunchtime to get the RIGHT bulbs....
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. 3rd brake light warning
    By madvenny83 in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2010, 07:26
  3. Brake warning light
    By dandsi in forum Suspension, Wheels & Brakes
    Last Post: 9th January 2010, 16:32
  4. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  5. Brake warning light
    By scar_vectra in forum Suspension, Wheels & Brakes
    Last Post: 23rd June 2007, 12:48
vectra c boot brake light message
vectra 2008 brake light warning
