Thread: Anyone fit a tuning box to my 2.0dti???
    South Wales
    confused Anyone fit a tuning box to my 2.0dti???
    I may be crazy risking the fragile fuel pump on my 2.0dti but i have gone ahead and bought a tuning box for it, is there anyone on here who could fit it, the guy i bought it from reckons it can be fitted in 20-30 minutes but as i have trouble finding the washer bottle its gotta be a no no for me to go hacking........ So is there anyone in the South Wales area who could help please, i can pay its no problem??????????????
    Regular Member Bullylad's Avatar
    Bolton
    Hi,
    There is a great guide for fitting a tuning box in the 'how to' section. I used it when fitting mine and it took about 30 seconds to do.
    The engine used in the guide might not be the same as yours but it should give you a good indication of what you are looking for.
    Good luck!
    South Wales
    cheers bullylad, unfortunately i had to have the engine where it needs to be wired in as opposed to one that just plugs straight in!!!!
    South Wales
    so i guess no one fancies a bash at fitting it?? Looks like i will be getting my cutters and insulation tape out
    Regular Member Steel's Avatar
    Sheffield
    Trim : Sri
    Mileage : 198,500
    I would have thought it would plug into the PSG5 connector on the pump, it has a slide lock which releases the multiplug and then the box goes in series to trick the ECU into giving it more fuel.
    South Wales
    no spoken to the guy at tandem tuning, the plug/socket on my car does require some wiring, its not a simple plug in but i do know the plug you are refering to
  1. 2.0dti tuning
    By madman in forum Diesel Engine related
    Last Post: 22nd June 2011, 21:21
  2. 2.0DTI Tuning box Help
    By redraptor_141 in forum Diesel Engine related
    Last Post: 31st July 2009, 20:54
  3. is there a zafira 2.0dti tuning box
    By Morephun in forum Engine & Drivetrain
    Last Post: 8th June 2009, 13:23
  4. 2.0dti tuning box
    By dervdoc in forum Diesel Engine related
    Last Post: 12th March 2007, 19:59
  5. 2.0dti tuning box??
    Last Post: 11th January 2007, 18:50
