Results 1 to 10 of 14
Thread: AFL Headlamp adjustment?
    Regular Member Matty H's Avatar
    Bristol
    Default AFL Headlamp adjustment?
    I've noticed on my car, when I'm following someone, that the driverside headlight is higher than the nearside. The driver side always looks really bright in the bumper of a car I'm following, whereas the near side only seems as bright when going over a bump or something.
    If you stand and face the car with the lights on and then slowly crouch down, the driver side melts your eyeballs before the nearside does. So is it possible to adjust the headlamp height? I've found the little alan key type adjusters on top the headlamp under the bonnet, but no matter how many times I turn them around it makes no different, so I was wondering if these are redundant on factory fit AFL and only work on standard headlamps.
    Any ideas anyone?
    Strangely, when you view the headlamp pattern agains the garage door they seem perfectly level, but they aren't
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Can't say I've noticed that on mine, if the lights had a levelling fault you would get the AFL warning light symbol flashing on the speedo display.
    Bristol
    Quote Originally Posted by leeds vectra View Post
    Do they automatically keep themselves level then with no manual adjustment? The drivers side is definately a bit higher than the near, meaning that the drivers side dazzles you over a bump or dip slightly before the nearside does. Dazzle is probably the wrong word but you know what I mean. I assumed that they are set at a level and then the auto levelling keeps them at that level as their set height but auto adjusts up and down on that level as road conditions dictate?
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Yes there are sensors on the rear and front axles along with a steering angle sensor. The only adjustment I'm aware of is for driving in Europe on the right. It may be compensating for the weight of the driver so driving slightly higher, it could also be just part of the system for the drivers side to be slightly higher.
    I have never noticed this but I have never looked for it either. I will keep an eye out on mine over the weekend.
    Bristol
    Cheers. Any feedback appreciated. Could be weight. I am a mere slip of a 14 and a half stone :P
    Regular Member JonV6's Avatar
    Cardiff
    So are we saying that AFL headlights can't be adjusted manually?.....
    My problem is that the beam simply isn't high enough. Obv high beam is the answer but when other cars are coming head on and I have to use dipped, I can't see ****!.....
    I wonder if adjusting the angle of the headlamp unit itself would work or would the AFL simply re-adjust to the old level? I don't think so because the AFL only takes level input from the axle sensors, there's no feedback as such. Has anyone tried this?
    Cardiff
    Just successfully adjusted my AFL Bi-Xenons by turning the white allen head plastic screw on top of the unit. 1 full turn has raised them about 3 inches at approx 10 yards so should spread some more light on the road!
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    Question
    I have exactly the same problem as you Matty
    Just got the car & the Drivers side about 6" too high with the ALF headlights
    & i'm 14 and a half stone
    it's going back to the Stealers to see what thay say
    or i may have a play like you JonV6 & see if that works
    Quote Originally Posted by Matty H View Post
    Cardiff
    It was mega simple TBH Thunder, prob not worth your time going to the stealer!
    Apr 2008
    North Yorkshire
    Engine : CDTi 150
    Mileage : 71000
    Thumbs up
    Thanks Jon i'll give it ago
  1. MPG adjustment on Op.com
    By mally in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2011, 12:40
  2. RHD to LHD headlamp adjustment
    By John LE in forum Electrical & ICE (including SatNav)
    Last Post: 3rd November 2010, 09:55
  3. Headlamp adjustment message after lowering
    By Harro in forum Suspension, Wheels & Brakes
    Last Post: 3rd April 2010, 18:28
  4. Headlamp beam adjustment for europe
    By goonturbo in forum Electrical & ICE (including SatNav)
    Last Post: 29th March 2009, 20:49
  5. Automatic headlamp range adjustment fault!
    By djhallam in forum Electrical & ICE (including SatNav)
    Last Post: 16th November 2008, 09:10
vectra afl symbol
opel vectra c headlights calibration
vauxhall insignia afl driving abroad
insignia headlights too high
auto levelumg sensor vectra c
vectra c afl lever adjustment
vectra c afl lamp
vectra c headlamp adjustment
astra j afl adjustment
2002 vectra c afl adjustment
2010 vauxhall insignia headlamp level sensor
headlamp adjustment on vauxhall vectra c
beam adjuster location vaxhall vectra
opel vectra c headlight leveling sensor fail
headlamp version opcom
vectra headlaiight calibration opcom
vectra c afl symbol blink
can vauxhall vectra c headlights be manually adjusted for driving on the right side of the road
