Thread: Clutch Problems
    Regular Member R13hard's Avatar
    Devon
    Engine : 2.0 Turbo
    Default Clutch Problems
    Today my clutch has started slipping!! i think
    Every time I try and pull away from stand still or accelerate whilst on the move the engine starts to rev but there is very little bite from the clutch and the revs go through the roof!
    it's a 2.2dti
    Please tell me that there is a simple fix and that i don't need a new clutch
    I have never experienced clutch problems so am unsure exactly what the problems are
    Regular Member EURO G's Avatar
    n ireland
    maybe just a clutch spring needing replaced mate quite common on vec and not that expensive hth
    Regular Member sparky71a's Avatar
    Apr 2006
    At the Garage
    I believe your motor has a DMF if so,they are very problematic.My first did 15k And was replaced under warranty.
    DMF=Dual Mass Fly Wheel.
    How many miles have you done?
    Are you warranty covered?
    Regular Member Stuarty's Avatar
    Aberdeenshire
    Sounds like your clutch is a gonner im afraid thats a sure symptom of a worn out clutch plate slipping
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Does it do it all the time?? Ie if you're traveling fairly slowly in a high gear, if you floor it and it slips then the clutch is knacked. That's about the bottom line.
    Devon
    Engine : 2.0 Turbo
    it's covered 70k, it seems to slip mostly when i'm travelling on the motorway at about 50 and try to then gain speed...sometimes it does this, Other times it is fine
    May 2006
    scotland
    Sounds like the clutch slipping. Ive had this on numerous cars over the past 30 years. I do not know what is involved in the Veccy clutch replacement but the old Vx mk2 Cavalier (FWD) was a doddle to replace, it just dropped out and new one slid in. Somehow I dont think the Veccy will be that easy. I had a slipping clutch replaced in a Rover Vitesse 10 years back and that was a swine of a job. Good luck.
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Clutch DEFINATELY knackered. Sorry mate.
    3.2 v6 Signum and loving it
    Regular Member videodoctor's Avatar
    Blackpool
    Half an hour job on the old Cavalier and i believe an 6 hour job on the veccy.They don't have to remove the engine though.I had a new clutch under warranty at 2000 miles and the engine stayed in the car.
    Btw. if anyone is still experiencing clutch judder on the facelift 1.8vvti after the new modified clutch has been fitted then take it back and get them to bleed the brakes and clutch cylinders.Mine juddered but after a full bleed is now smooth as a baby's bot!.
  1. yet more clutch problems!
    By DinningtonD in forum Engine & Drivetrain
    Last Post: 1st August 2012, 18:46
  2. clutch problems
    By sebadee in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd January 2011, 23:27
  3. Clutch problems
    By emmysnail in forum Engine & Drivetrain
    Last Post: 25th April 2010, 09:26
  4. Clutch Problems??
    By trublu24 in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2009, 13:18
  5. Clutch Problems
    By bryangarner@hotmail. in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2008, 18:23
