Thread: Front Seat Removal.
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    Question Front Seat Removal.
    I've got my seat squeak back (it's driving me crazy) after the dealer said it was fixed, so this weekend i intend to take the seat out and wd40 everything that ain't foam or cloth !
    My question is if i take the seat out, is it going to start illuminating the dash warning lights for the airbag or anything else that i'll have to go into the dealers to sort out ?
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    It shouldn't do, when we did paul's drivers seat that went back in no hassle, with no lights either.
    Regular Member cameraman's Avatar
    Leicester
    Don't turn the ignition on with the seat disconnected, else you may get airbag warning lights
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    slide the seat forward and on the rails there are two t40 bolts undo them and tilt the seat up towards the front and pull back slightly and then lift out but remember to undo the seat tensioner wire first and on the side of the seat is the seat belt bolt with i think is a t30/35
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    just ease the hight adjuster up a notch, this worked on mine mate
    Midlands Mod Shop - NFFC.
    Mileage : 000
    Phil I will be taking Larisa,s motor to bits tomorrow if you want to pop over to my place then off to " the farm" we can have a look at it then if you like.
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    the light will only come on for the time the seat is out.
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by cameraman View Post
    Just don't turn on the ignition all the time the seat is out/disconnected.
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Remember wd40 is not really a greasing type oil, it is more of a penetrating oil to free stiff nuts and bolts. You would be better to use some type of spray on grease, Which you can buy at any decent auto shop.
    3.2 v6 Signum and loving it
    6 Post(s)
    Year : 1 A.D
    Mileage : Rising
    Quote Originally Posted by Johnsdutton View Post
    I've got some graphite grease that i use in my fishing reels, that should do the job.
    Thanks all for the replies. Vec-C rules ok !
  1. seat removal
    By dilan in forum Bodywork & Interior
    Last Post: 29th April 2012, 15:37
  2. Front Seat Removal
    By Tam80 in forum Bodywork & Interior
    Last Post: 14th September 2010, 22:48
  3. seat removal
    By texaspete1973 in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2010, 20:51
  4. Front seat belt removal
    By kel123 in forum Bodywork & Interior
    Last Post: 11th July 2007, 17:10
  5. Front seat airbag removal
    By monkeybusiness in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2006, 09:27
