Results 1 to 10 of 11
Thread: Help with aftermarket head unit
    Regular Member siross's Avatar
    Oct 2007
    Default Help with aftermarket head unit
    Hi, just bought a full can bus adaptor from craigmerry, tried figuring out how to fit it, and the lead doesnt fit into my head unit (Alpine ida-x001).
    Do I need another connector? As in iso-alpine connector like this:
    http://cgi.ebay.co.uk/ALPINE-16-PIN-...QQcmdZViewItem
    lanark
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    not sure mate but one of the guys in the know will be along shortly to help you
    gwent
    I don't think you got the right plug i bought one from alpine with steerring wheel controls and it fitted with no problems.Looking at the one you brought there's a black box missing ware head unit lead should go?
    Oct 2007
    i havent bought that one from ebay, i bought this:
    http://forum.vectra-c.com/showthread.php?t=46172
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    Quote Originally Posted by siross View Post
    you need to buy the wire with a jack on the end from halfords. they are about 4 pound and it will replace the one on the adaptor, just clips out of the main box. the one on it i think was for a sony radio thats what craig had.
    Oct 2007
    a jack?
    i need a 16 plug pin for the alpine head unit?
    Feb 2007
    a jack?
    looking at the pic of the adaptor you need the piece of wire to replace the one there with the jack on the end. the 2 blocks from your stereo lead plug into the block on the adaptor and the one remaining lead plugs into the cars loom. the other piece is for the ariel.
    Oct 2007
    Im assuming that the jack is for the steering wheel controls? that fits without a problem.
    the smaller plug which is wired to the plug for the car is an iso plug (i think) so therefore i need an alpine to iso lead but am not sure
    can anyone confirm?
    Feb 2007
    can anyone confirm?
    the jack may fit but if its not for an alpine it wont work. the smaller plug should plug into the block of the cars wiring loom thats what gives the power to the stereo and the adaptor. then plug the stereo blocks to the remaining blocks into the adaptor and it should work! just dont plug the jack into the stereo straight away as the steering wheel wont work. you have to switch the ignition on store a radio station, then switch everything off, plug the jack into the stereo switch ignition on then everything should work hope this helps!!!
    Full Member lochgilp's Avatar
    argyll
    You will need the alpine iso lead to connect into the other lead?? 16 pin but you should have that with your alpine headunit anyway mate, unless you left it in your old car
  1. Aftermarket head unit
    By Alansvecky in forum Electrical & ICE (including SatNav)
    Last Post: 2nd December 2011, 20:23
  2. Need help for installing aftermarket Head Unit
    By the-converter in forum Electrical & ICE (including SatNav)
    Last Post: 7th October 2010, 16:00
  3. Help with fitting an aftermarket head unit.
    By alembicbassman in forum Electrical & ICE (including SatNav)
    Last Post: 28th August 2010, 19:29
  4. Does having SatNav on Vec mean you can't fit aftermarket head unit?
    By Rikkiola in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2008, 21:03
  5. Aftermarket Head Unit Conversion?
    By Cheeky_B in forum General Chat
    Last Post: 11th November 2005, 18:50
