Results 1 to 3 of 3
Thread: Knocking suspension
    Regular Member marko21's Avatar
    Apr 2008
    Lancs
    Default Knocking suspension
    I have the common (new to this forum but obviously a v-common problem) Knocking suspension. I thought it was mainly when going over the many speed bumps but now it appears that there are noises from my upper rear mounts when driving normally.
    The car is still(one month remaining) under network Q guarantee. I have checked here and other members say that the cars covered but when i look at this site http://www.networkq.co.uk/nq/morefro...rsguarantee.do
    it says
    What's not covered
    • Bodywork
      All bodywork and body trim, glass, paint, sheet metal, sunroof panels, water ingress and door seals.
    • Service Items
      Service items, including but not limited to oil filters, lubricants, points, spark plugs, fuses, wiper blades, tyres, bulbs, auxillary drive belts, rotor arms, condensers, exhaust systems (but catalytic converters are covered), anti-freeze and other fluids – unless the replacements are required because of a failure of a covered component.
    • Miscellaneous
      CV boot, Macpherson struts, shock absorbers, adjustments
    • Modifications
      Modifications that are made to the vehicle by the customer after the delivery date of the vehicle.
    • Contaminated or incorrect fuel
      The clearing of fuel lines, filters, carburettors, pumps and the replacement of catalytic converters damaged after the use of incorrect or contaminated fuel.
    • Electrical Accessories
      Satellite Navigation units, telephones and associated equipment of all types.
    Does this mean that they are NOT covered and should I take it to my local mechanic.
    Or is there a How2 to maybee sort this myself(what is the difficulty level?)
    marko21
    Regular Member mitchell's Avatar
    northumberland
    its the bushes that go and i've just got mine sorted toady under the network Q
    Apr 2008
    Lancs
    Sorted the problem by a little WD40 on my anti roll bar bushes and Drop links. There were horrendous noises until I removed all wheels, lubed and cleaned of the lower spring seats, this has worked wonders. I took 30 mins and it feels like a new suspension set up.
  1. suspension knocking again
    By wirrallad in forum Suspension, Wheels & Brakes
    Last Post: 2nd June 2012, 18:30
  2. Suspension knocking? Will Vec c suspension fit a Siggy?
    By shane5861 in forum Handling & Braking
    Last Post: 6th May 2011, 14:20
  3. Knocking suspension
    By cosjon in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2010, 14:55
  4. knocking on o/s suspension
    By marktaylor in forum Vectra C / Signum Car Chat
    Last Post: 29th June 2010, 15:18
  5. Suspension Knocking
    By D-S-Dave in forum Suspension, Wheels & Brakes
    Last Post: 3rd August 2007, 01:31
