Thread: this is what the problems were on my vectra what do u think
    Apr 2008
    gateshead
    Default this is what the problems were on my vectra what do u think
    hi all on to here to seek advice about the reason my car wont start
    its a 04 2.0 dti
    had one previous fault (pulley wheel) which vx fixed under warranty
    when you turn the key it clicks like a clunk(i thought starter motor)
    so i tried to bump the car it dont want to know
    it doesnt even make a noise like a car does when you bump it ie belts and cogs turning
    ive tried it with jump leads still no go
    question
    can the car be bumped with a broken starter
    ive have had a look at the car
    and so far i can tell you this
    he has no warning indicators or spanner lights
    battery works lights/radio etc still works
    he has removed the battery for upto four hours and my conclusion would have been his ecu after removing battery
    i looked at his key fob and opened it and see no small silcon chip in the head as my 02 plate astra does(but after reading these boards i assume the veccy c 2.0 dti 04 plate dont have the chip
    but the radio has still kept its code
    any help would be greatly appreicated my brother inlaw is not in a finacial postion to get vx to sort so all comments advice would be helpful
    thanks all
    Apr 2008
    gateshead
    well here goes ive had a mobile mechanic out its been on diagnostics
    1 the battery is goosed
    2 starter needs replacing
    3 wiring loom needs tracing to ignition as its shorted
    getting charged 300 notes does this sound right
    also they said the hydolics were goosed 4 the rear brakes and that added an extra 90 quid
    Sunny Dartmoor
    1 the battery is goosed-new battery i'd say £70
    2 starter needs replacing-New starter i say £85
    3 wiring loom needs tracing to ignition as its shorted- this can be as long it takes to fix fault........
    Has the work been carried out? If not how can he fix a fault on the short if he hasn't found it yet........????
    Apr 2008
    gateshead
    Quote Originally Posted by glenboy View Post
    yes mate all the work has been carried out come to a total of 410 pounds
  1. 5 problems with our new Vectra C
    By Rod C in forum Bodywork & Interior
    Last Post: 8th March 2013, 22:51
  2. few problems on my vectra
    By abz123 in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2012, 11:39
  3. Vectra problems
    By ian1964 in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2012, 18:37
  4. Got a few problems with the vectra!
    By Bigtee in forum Vectra C / Signum Car Chat
    Last Post: 16th September 2010, 06:35
  5. Vectra Problems
    By paulhb in forum Engine & Drivetrain
    Last Post: 13th September 2009, 14:06
