Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
Thread: I just blocked off my EGR valve!
  1. #11
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    I have a mate who has a Zafira 1.9 cdti 150 and his EGR packed up and the dealer said straight away that there was a delay in new parts and so removed/ disabled the EGR and he says it runs just as before.
    He also runs it on 50/50 mix of diesel and Aldi vegatable oil and again says that it runs like a dream.
  2. #12
    South Central England
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    The EGR is only any good on new cars, after a year it's doing more harm.
  3. #13
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I wouldn't use pure vegy oil in it, the glycerin in the oil could varnish the pump and reduce it's life. Processed to remove the glycerin and free fatty acids it should be fine though.
  4. #14
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Quote Originally Posted by nutron View Post
    My car has been in to the dealers and they told me the RGR Valve needed replacing, that was 2 weeks ago, since I returned home the emissions light is constasntly but the car drives fine, would this be normal if the valve needed replacing?
  5. #15
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Yeah, it can be un-noticeable depending on how the valve has failed.
  6. #16
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    As it stands seems to drive fine but would it get progressively worse and fail totally, would I be correct in saying that?
  7. #17
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Again, I don't know how it has failed but if the solenoid has seized like most then it shouldn't get any worse.
  8. #18
    Leicester
    I agree with Karl here, I think it even states in the Vauxhall hand book about using vegi oil the cars and warranty etc.
    It is not wise to use any vegatable oil in common rail diesel cars.
  9. #19
    Regular Member Kcs's Avatar
    Feb 2007
    Tamworth
    Default EGR
    I have read a few post on this subject, so i am thinking that the normal
    operation of the EGR is : when engine is at idle the valve is open, and
    as rpm picks up as you drive, the valve closes ! if this is correct, blanking
    the EGR will just make the engine run as it should do ? some people say
    their cars have more torque, others say it feels the same !
  10. #20
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    That is indeed how it works (with some variation for load as well) but the ECU get feed back of whether it is operating from the mass air flow sensor. This means that although it should run correctly you may get a fault light. The big problems come when the valve get jammed open, this could happen because of either carbon build up or the solenoid corroding and sticking in the open position.
    If you do get a solenoid stuck open then remove it and hammer it back in. Carbon build up is obviously quick simple to sort, you just clean it off and put it back but make sure you oil it.
  1. blocked cat on a 2.0t
    By tomo41 in forum Engine & Drivetrain
    Last Post: 12th June 2011, 22:50
  2. Well, Vectra-c's been blocked now...
    By Leemarksmith in forum General Chat
    Last Post: 16th July 2010, 20:05
  3. Wonder if this guy blocked his egr!
    By John LE in forum The 'Off Topic' room
    Last Post: 21st June 2010, 09:09
  4. Blocked exhaust
    By katmart in forum Engine & Drivetrain
    Last Post: 18th June 2009, 17:51
https:www.vectra-c.comforumshowthread.php46310-I-just-blocked-off-my-EGR-valve!
