Results 1 to 10 of 21
Thread: I just blocked off my EGR valve!
    South Central England
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Default I just blocked off my EGR valve!
    That's right folks you hear it here first, you can block off the EGR valve on the 1.9CDTI without any trouble from the ECU... If you have it remapped first to stop the EGR comming on
    Still it does show that if Vauxhall wanted to sort this problem out, even just in the short term while they wait for more valves; they could make a cheap gasket and knock out a software revision to disable the EGR.
    I guess Vx just like to see people suffering?
    Regular Member craigmerry's Avatar
    Jan 2008
    midlands
    Stick it ebay, you'd make a fortune
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Well I've been out thrashing the car about to get it hot and driving it through all rpms and loads to make sure that the gasket would be exposed to heat/pressure if the EGR was opening. I then took the EGR off again to see if the gasket was still intact and if there were any signs of carboning. The results are an massive success! So everyone with a dodgy EGR, ring Vx and ask them why they can't do the same while you wait for a part!
    Although, you might want to get Vx to make you one out of something other than a Dr Pepper can
    Regular Member sonic's Avatar
    Feb 2007
    Away with the fairies.
    Whats an EGR valve? What does it do?(or not!)
    Regular Member mushy2007's Avatar
    Liverpool
    How about a Redbull can!
    Regular Member 06 vectra's Avatar
    Jan 2008
    meigle
    why not after all it does give you wings
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Well dome Nutron. The Field remedy for the z22se EGR is just to turn it off via tech 2 and blank it of with a VX blanking plate. There is a part number for the plate, you never know it might fit the CDTi. There's a guy on the 2.2 forum who makes a cheater so we can disable it ourselves for a tenner.
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Isn't the 2.2 the same as the old Y20DTH, in that it uses a vacuum to open and close the EGR? The one on my Vectra-B was a completly different shape and the Dr Pepper gasket is holding fine
    I wonder what else I can block off?
    Vehicle : SRi
    Mileage : 137000
    Not that im aware, vids done his but as of yet I think its just cabled tied up but still connected to the loom.
    Regular Member Vid's Avatar
    May 2007
    In the inventing shed...
    Mine is just bolted to the blanking plate, so that it can open into the atmosphere, i.e. open and close as normal, but no gases pass through it!
    Didn't have any reprogramming done, and was no problem!!
  1. blocked cat on a 2.0t
    By tomo41 in forum Engine & Drivetrain
    Last Post: 12th June 2011, 22:50
  2. Well, Vectra-c's been blocked now...
    By Leemarksmith in forum General Chat
    Last Post: 16th July 2010, 20:05
  3. Wonder if this guy blocked his egr!
    By John LE in forum The 'Off Topic' room
    Last Post: 21st June 2010, 09:09
  4. Blocked exhaust
    By katmart in forum Engine & Drivetrain
    Last Post: 18th June 2009, 17:51
