Thread: new fix for steamed up fog lights
    Regular Member kns's Avatar
    Northampton
    Default new fix for steamed up fog lights
    Hi All,
    My passenger side fog light kept steaming up, so after telling the stealers and Vauxhall that Iím not happy about this as I have done the 20 minute test and all is well until the next day and it happens again.
    I told them that this is not acceptable to keep putting my fog lights on for 20 minutes a day just to clear them.
    The stealers phoned me today to say there is a new fix out and itís called a snorkel which is a part they attach to the back of the fog light so it can breathe.
    Now all I have to do is wait for the parts to come in result.
    If youíre not aware of this fix and your fog lights keep steaming up get on to the stealers and ask for it.
    So no more wasting 20 minutes fuel to clear your fogs as I am not one of these numpties that drive with their fog lights on in the day time or night come to think of it unless it is foggy
    Full Member Big Sig's Avatar
    Try and get a part number for it!
    Northampton
    will do once stealers book it in
    Sunny Dartmoor
    I need this mod,part number will help...........
    Regular Member chrisschild's Avatar
    May 2006
    Wiltshire
    Vehicle : Vectra Hatchback
    Engine : 2.2 DTi
    Is this Pre-Facelifts too? Mine do the same, thinking about it, so did my other Pre-Facelift too!
    Regular Member Perry's Avatar
    Watford Herts
    Mine does it as well, even after Vauxhall changed the unit for a new one.
    Regular Member Matty H's Avatar
    Bristol
    Vauxhall lights on general are rubbish for steaming up. I've had two veccys and an Astra and they've all had various problems with moisture in various lights. My brand new one has moisture in th fog lights, front right (as you face it) headlamp and rear boot brake light. Rubbish!
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    is this mod available for pre facelift vects?
    How about a "free" fix...
    On the SRI bumper the under tray is in three parts, each fog lamp is protected by one of these parts
    Undo the clips and remove the associated small tray
    The fog lamp is protected by the this tray so this fix can actually be performed without removing it, but I recommend removing the fog lamp
    Disconnect the wiring, unclip, and pull from the bumper
    Remembering which side of the fog lamp housing is the top, drill a 10mm hole into the top
    (If you did not remove the fog lamp, then drill the hole into the bottom, this is OK as the fog lamp is protect from any water by the tray)
    Reassemble
    Job done!
    If you have the same problem with your headlights, then simply remove the rubber cover, leave for about 12 hours overnight
    Replace the rubber cover
    Job done!
    It's always the simple things in life that work best
    Aberdeen
    Or put a packet of theat sillica gel in the lights.
  1. fog lamp steamed up
    By skidmark1 in forum Bodywork & Interior
    Last Post: 26th September 2011, 21:33
  2. im all steamed up
    By mattolly86 in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2008, 23:49
  3. All steamed up..
    By macdad in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2008, 15:16
  4. Steamed up lights
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2008, 15:47
  5. Steamed up fog light
    By Jim Bob in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2006, 19:53
