Results 1 to 10 of 17
Thread: Wheel vibration after new tyres. Rebalanced twice.
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    Default Wheel vibration after new tyres. Rebalanced twice.
    My veccy 2006 came new fitted with Bridgstone ER30 Turanza tyres, I recently replaced the fronts when they were getting close to 2mm.
    Since having them fitted I have noticed very slight steering wheel vibration around the 80mph mark, and it is only slight. I have had them re-balanced twice now at different garages but its still there just a touch.
    There was no vibration evident at all before the tyres were fitted. I thought I had sussed out the problem when I noticed that the tyres were fitted the opposite way round to each other, but when I mentioned this I was told they were not directional tyres and it did not matter how they were fitted. The steering seems a little better having done a few miles but still not perfect.
    My wheels are the standard VX 16" steel structured wheels that look like alloys but are not..LOL. I am thinking about fitting proper alloys for the looks. AAMOI are alloys easier to balance as there contruction is more precise, or are the balancing issues the same, which I assume they are.
    In any case I think I need to find a garage with good balancing machine. :-))
    The vectra is very fussy with balancing, I had to swap my wheels front to back which sorted it ...
    Chester
    The tyre place I've been going to for 20 years could not balance the wheels on my Vec. That was an Exclusiv too but it was the new alloys that they could not do.
    You need to find a place that uses a Hunter machine or something similar and ask for them to be done on "Fine" settings.
    Maybe there is someone in your region that can recommend a good garage.
    More info in this thread.
    http://forum.vectra-c.com/showthread.php?t=21096
    (Welcome to Vectra-C BTW )
    Regular Member shippers's Avatar
    Jun 2007
    driffield
    Could be a tyre that is out of shape ?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Try swapping the n/s front with the o/s front. This worked on my GSi
    Alfreton, Derbyshire
    Try to swop them rear to the front and front to the rear, all new tyres need to wear down so called 'an initial rubber' which usually takes a couple hundred miles, I had to balance my 19"s five times before they stopped vibrate. They still do a tiny bit but I'm not worried too much at the moment.
    Also sometimes the tyre fitters go an easy way and when they do balance wheels they leave a tolerance of 5 - 10 grams out. this also can cause the wheel to vibrate a bit. Let them do 0-0 read out on the balancer and it should be fine afterwards. Hope this helps.
    11 Post(s)
    I take it when they fitted them they lined up the yellow painted dot on the tyre with the valve stem?
    Regular Member signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    try not doing 80 mph
    Apr 2008
    In UK
    I managed to find a specialised tyre centre which does have decent balancing equipment, and this time they seem fine, not cheap at £20 for 2. Thats the trouble being a perfectionist.
    Its obvious that a lot of garages are using crap balancing gear.
    This is the third attempt at getting them balanced right but well worth it. At least I know where to go next time.LOL
    Thanks guys.
    Regular Member S14RRJ's Avatar
    Lancashire
    Quote Originally Posted by signumboy View Post
  1. Wheel Vibration
    By wayneg88 in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2012, 02:20
  2. Wheel vibration at over 70+
    By simonturner1975 in forum Suspension, Wheels & Brakes
    Last Post: 6th March 2010, 11:22
  3. wheel Vibration
    By Stephen S in forum Suspension, Wheels & Brakes
    Last Post: 20th November 2009, 16:57
  4. CRACKED Alloy wheels, vibration, and tyres . Please please help !!
    By mcmcnaughties in forum Suspension, Wheels & Brakes
    Last Post: 11th March 2009, 19:49
  5. Vibration since new tyres
    By greeningr in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2007, 13:43
new tyres now wheel vibration balancedtwice
How much to have a vectra rebalanced
had new tyres fitted and wheels vibrate at 70mph - had them rebalanced twice and still the same
