Results 1 to 10 of 11
Thread: Computer problem.
    The Blackburn End
    Default Computer problem.
    This problem has annoyed me because its an accumilation of a few things on my home laptop.
    Firstly, I ditched the Wanadoo wireless broadband internet & account because it kept breaking and I was going through a wireless router ( Livebox) every month.
    Secondly, when the new BT broadband software & wired router arrived, the CD-rom wouldn't run properly because the driver had mysteriously vanished.
    So, I can't download a new driver because I've no internet connection and, I can't install a internet connection because the CD-rom won't install the software because, there's no driver for it !
    Do I bite the bullet and take it to one of those horrible PC World things for them to rip me off ??
    Has anybody got any suggestions whose computer savvy ?
    PS: In case anybody wonders how I'm doing this, I'am writing this on my office computer in my works at 9.25pm.
    Hertfordshire
    I guess the most obvious that springs to mind is, portable storage, get yourself some kind of memory card, stick or what ever, theres loads out there now a days.
    Download the driver at work, save it onto the stick/card and then take it home and plug it in, being a laptop, you should have either PCMCIA ports or/and USB.
    Here, there and every where!
    can you download the driver whilst in work and put it on a disk?
    Regular Member MJED's Avatar
    Shropshire
    Scottex, if you can get hold of a USB memory stick/pen, you could transfer the drivers that way, as the USB pen will mount its self as a removable drive. As for the driver for the BT thingy, PM me with your email and I can send it to you.
    Mark
    The Blackburn End
    Thanks for the ideas, it will have to be a USB memory stick, no point put it onto disk as the cd-rom in the laptop won't read it as it says the driver is not there o make it happen. Again thanks for the ideas.
    If you have a standard 56k modem in the Laptop use that to download what you want using a dial up connection. Depending on the file size it may take a bit longer, but at least it stops you messing around burning discs etc.
    Regular Member joules2.0t's Avatar
    surrey
    Trim : SRI
    Year : 53
    What OS are you running?
    N.Wales
    Quote Originally Posted by SCOTTEX
    tbh i've never heard of a cd-rom requiring a driver.... well, i know they do need drivers but normally any OS from say windows 98 > will auto recognise the driver. thats puzzled me!
    Dec 2005
    In the sponge-monkey tent
    You don't always need drivers for routers, if it connects to your PC via an ethernet cable rather than USB. Plug it all in and pull up a browser window, type the following in the address bar:
    http://10.0.0.2
    This should bring up the routers set up page, you will probably get asked for an admin username/password which should be in the manual (either paper or pdf on the disc). You should then be able to set the log-in username and password for your ISP manually.
    p.s you shouldn't need a driver for your CD-ROM drive as Windows has native drivers for these, unless of course it's an old laptop and the drive is external then you may need one.
    The Blackburn End
    Thanks Neil, I'll try it but I can't do it today. I'll let you know.
  1. Problem with onboard computer
    By ian124 in forum Electrical & ICE (including SatNav)
    Last Post: 25th December 2010, 14:50
  2. Got a computer problem, can anyone help?
    By purple170503 in forum General Chat
    Last Post: 1st May 2008, 17:01
  3. Computer problem
    By silverhairedracer in forum General Chat
    Last Post: 27th August 2007, 16:48
  4. Fuel Computer Problem
    By VectraV6CDTi in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2006, 22:00
  5. Computer Problem!
    By Caterman in forum Comedy & Humour
    Last Post: 19th February 2006, 00:18
