Results 1 to 10 of 23
Thread: petrol in oil??????
    Regular Member mitchell's Avatar
    northumberland
    Default petrol in oil??????
    noticed oil on drive today where the siggy sits. wife jst came home so went out to have a quick look. oil dripping off the bottom of the plastic moldings on the drivers side front wishbone area. opened bonnet to check oil and the dip stick was a little rusty, then i noticed the smell of petrol a rub of me fingers on the dip stick and it wa scovered in petrol............any ideas as it's going to the stealers tomorrow for the anti roll bars to be done and would like some ammo to go with.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    petrol in oil is '' bore washing '', speak to (hugh) j13hdb as he suffered with this this after a dodgy remap
    Midlands Mod Shop - NFFC.
    northumberland
    whats the cause of bore washing.....not had any re map done???
    Trim : Get a
    hugh's was due to a bad re-map, but could just be overfueling in your case, what is the mpg like ????
    northumberland
    about 26.9 ish sitting at 0.3 gal/h at idle ????
    Trim : Get a
    i'm a bit out of my league here so will just ask is that about right for your car ????
    also when at the dealer's tomorrow make sure you tell them to check it out, it is detremantal to the engine if it is '' bore washing ''.....
    i might be completly wrong about this though so will finish with a good luck and keep us posted
    [Ex]Admin Duncan's Avatar
    Definitely sounds like it could be bore washing, or piston rings somehow worn? Basically petrol getting past the pistons and into the oil.
    If the car is badly overfuelling then that could be the reason for excess petrol in the combustion chamber not being burnt and getting past the pistons. I don't know the average mpg for a 2.2, but 27 doesn't sound too far from what it should be.
    Whatever you do, you need to get an oil/filter change on the car ASAP to get rid of the petrol in the oil - then see if you can find out why the petrol is getting there. e.g. is it overfuelling or is it because of worn piston rings etc.
    northumberland
    cheers duncan......regretably thinking of telling them where to park it (ie. where the light would need to be on all the time) and maybe look for a veccy.
    N. Ireland
    Quote Originally Posted by mitchell View Post
    im no mechanic mate but it could be overfueling, the 0.3 gal/h might be a we bit to high mine sits at 0.1 and 0.2 in the morning when its cold. im averaging about 30mpg as well (2.2)
    northumberland
    cheers jaxouk. trip to the stealers tomorrow and some serious a$$ kicking coming up.
  1. which parts of a 2.2 petrol direct duel exit exit will fit a 1.8 petrol?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2012, 10:25
  2. 1.8 xe SRI Petrol
    By otto in forum Engine & Drivetrain
    Last Post: 27th June 2010, 22:02
  3. What oil for 2.2 petrol
    By Perry in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2010, 23:30
  4. 2.2 petrol cat...
    By danBoy in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 15th June 2008, 20:05
  5. 2.2 Petrol MPG
    By vectrasri03 in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2006, 14:49
