Thread: Stripping front door panel to fit speakers
    Apr 2008
    Middlesbrough
    Default Stripping front door panel to fit speakers
    Hi all, I have a new pioneer headunit installed and now have some pioneer speakers to mount in the front doors.
    Im unsure how the door panel comes off and how to take it off right in order not to damage it so that i fit the new speakers
    Please help...Thanks
    Administrator plasma's Avatar
    On the Forum
    357 Post(s)
    Engine : 150
    Mileage : 74000
    Door handle trim off. Remove torx screws. Bottom of door card, 3 x ( i think) torx screws remove these too. Rest of the door card held on by them annoying plastic pop thingys. Once door card away, disconnect switches and cable to door release mechanism.. think thats about it..
    Apr 2008
    Middlesbrough
    Cheers pal, sounds straight forward i will give it a whirl, think it will be saturday now because of the weather.
    Them annoying plastic pop thingys will just a good tug bring them off or is there a better way to get them off and can i reuse them or need to buy new ones to fit the door back together.
    Regular Member mitchell's Avatar
    northumberland
    CHRIS you can get proper trim removal tool. but just use a very large fat flat screw driver and prize the door card away slowly from the clips and you should be able to reuse. HTH
    Apr 2008
    Middlesbrough
    Yeah i will do thanks man, i take it you just apply pressure in order to pop it back on again
    On the Forum
    357 Post(s)
    Engine : 150
    Mileage : 74000
    yepper.
    Mileage : 000
    There is a "how to" in the how to section on the user cp for a full detailed how to change the speakers.
    preston
    Just a tip when refitting the door cards to your cars which I've used on several of my cars before which stops the plastic poppers breaking and it works too! Before refitting just put a blob of grease on each popper so when you need to remove the door card again,it enables the popper to slip off a little bit easier and stops them breaking which is a pain if you haven't got any handy.
  1. front door speakers
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 24th July 2011, 03:50
  2. Front Door Speakers-Vec-B
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2009, 09:33
  3. Front door speakers ,mid price , any suggestion
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 21st June 2007, 12:44
  4. Front door speakers
    By alzsxi in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2006, 20:55
how to change vectra c front speakers
vectra front speaker remove
how to change speakers on a vectra c
signum elite door speakers
speakers to fit vauxhall vectra c
how to replace speakers in vectra c
how to fit 17 inch speaker to vectra c
