Results 1 to 10 of 14
Thread: cold start
    york
    confused cold start
    thirst thing when starting from cold car only starts on 3 cylinders kicks out mass amount of smoke and doesnt run right till warm then starts fine after that its done 33000 miles and has proper service intervals well looked after although do use placebo deisel cleaners every once in a while its an 07 1.9 cdti 120
    Mileage : 000
    Not that I know too much about diesels. But I would say that one of the pre-heaters is not working,
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I would agree, sounds like a glow plug not functioning correctly.
    Is the smoke black or white and smelly? Does it run 'lumpy' at idle too?
    When you say warm, do you mean it takes until the engine has warmed to near normal operation before it runs OK? Or just something like half a minute? If it doesn't get better till it's nearly reached operating temp, then it may be more than a defective glowplug, perhaps an injector or an injector seal.
    Have you tried using a diesel injector cleaner fuel additive ?
    Are all the air hoses completely sealed and no splits?
    york
    the engine has never been touched apart from new fly wheel at 6000 miles so donf think iinjector cleaner bout once a month only dous when really cold then fine but runs a little lumpy and doesnt seem to be as powerfull lately neither
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    sorry, but I don't understand that at all.
    This sounds like you have an injector staying open and dumping fuel into the cylinder i am sure there was an issue with the injector wiring on some CDTi 's and it came back as an "open circuit" as far as heater plugs go they will only come on if the car decides it is cold enough to need them and i have never heard of any veccy cdti needing them !!!!they just dont break anymore !!!
    Portadown, N.I.
    Quote Originally Posted by alijlacy View Post
    I'd say you are within the warrenty period, take it back to the dealers and get them to fix it
    Tim
    Feb 2006
    Guttedsville
    Quote Originally Posted by spuddevans View Post
    Tim
    Absolutely. Sounds a lot like a goosed injector.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    duff injector, and a warranty issue imo, a trip to the dealer's for you mate
    Midlands Mod Shop - NFFC.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    yep, covered under warranty. Maybe I should have looked more closely when you described the car, age etc
  1. smoke at cold cold start
    By azacbr6 in forum Engine & Drivetrain
    Last Post: 5th December 2012, 18:23
  2. cold start
    By abz123 in forum Engine & Drivetrain
    Last Post: 15th October 2012, 22:24
  3. vec b cold start
    By twaiter in forum Engine & Drivetrain
    Last Post: 27th March 2011, 14:59
  4. 2.2 dti cold start
    By tomo610 in forum Diesel Engine related
    Last Post: 2nd January 2011, 10:47
  5. Cold Start
    By T4M in forum Engine & Drivetrain
    Last Post: 10th July 2007, 20:47
