Thread: Bilstein B6 + Eibach Pro 30/30 - Sanity Check ...
    Regular Member hans_vledder's Avatar
    't Veld - The Netherlands
    Default Bilstein B6 + Eibach Pro 30/30 - Sanity Check ...
    Guys,
    As I've mentioned before I am planning to lower my car by 30/30. At the same time I will renew the shocks of my car and fit some 345mm/292mm calipers and discs. I am considering getting Bilstein B6 for both front and rear and combine these with a Eibach Pro lowering spring kit.
    I've noticed that you guys are enthousiastic about lowering, Bilstein's and Eibach, but what exactly can I expect from upgrading to this combination of parts. Before I spend some money on the upgrade, what will I end up having?
    Regards,
    Hans
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    not gone there myself but all i can say is when j13hdb had them fitted to his signum the difference was amazing ...............pity his re-map wasnt as good...
    car felt as a passenger totaly different and a lot more planted on the road
    hth and if not a free bump
    Midlands Mod Shop - NFFC.
    Regular Member corman's Avatar
    Mar 2007
    hexham
    http://forum.vectra-c.com/showthread.php?t=46217
    double post
    maybe a mod can combine (the threads not a field!)
    Quote Originally Posted by corman View Post
    double post
    Yep, every now and then this happens to me. First post comes back with a message saying that I have to wait 30 seconds before posting. After that there are two posts. I appologise ...
  1. Bilstein B4 + Eibach Pro
    By taiko in forum Vectra C / Signum Car Chat
    Last Post: 14th August 2016, 18:57
  2. Bilstein B6s or Sachs + Eibach 30/30 or SRI 15/15?
    By Drazek in forum Handling & Braking
    Last Post: 28th May 2012, 09:52
  3. Bilstein B6 + Eibach Pro 30/30 - Sanity Check ...
    By hans_vledder in forum Handling & Braking
    Last Post: 22nd April 2008, 20:11
  4. Bilstein / Eibach part No check
    By grattygruff in forum Handling & Braking
    Last Post: 28th September 2007, 15:29
  5. Z19DT and Z19DTH Sanity Check Please
    By denzo in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2005, 23:44
