Thread: can a car be bumped if the starter is cattled
    Apr 2008
    gateshead
    Default can a car be bumped if the starter is cattled
    all help appreciated
    Not sure about diesels, but you definitely shouldn't bump start a petrol car that has a cat. You'll dump a load of unburnt fuel into the cat and wreck it/shorten it's life.
    Somewhere I probably shouldn't be
    As long as it's not jammed in the flywheel, should be ok.
    I know many years ago the main 12V coming from the battery was fed directly to the starter and if there was an connection problem then you'd struggle, but it shouldn't be the case on a modern car.
    You can reduce the life of the cat, but it's ok for the odd occasion.
    Regular Member Inspektor's Avatar
    Northampton (Santa pod)
    Not if it's an auto.
  1. My Vec got bumped
    By monty2000 in forum The 'Off Topic' room
    Last Post: 5th September 2011, 19:01
  2. starter solenoid or starter cdti 150 help!!
    By veralum in forum Engine & Drivetrain
    Last Post: 27th April 2010, 19:57
  3. Got bumped from behind
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 4th April 2009, 12:09
  4. ive just bumped your car!!!
    By big rich in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2009, 13:18
  5. Bumped The Vectra
    By jonnye in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2007, 20:44
