Results 1 to 10 of 13
Thread: help urgently needed any help greatly appreciated
    Apr 2008
    gateshead
    Default help urgently needed any help greatly appreciated
    hi all on to here to seek advice about the reason my car wont start
    its a 04 2.0 dti
    had one previous fault (pulley wheel) which vx fixed under warranty
    when you turn the key it clicks like a clunk(i thought starter motor)
    so i tried to bump the car it dont want to know
    it doesnt even make a noise like a car does when you bump it ie belts and cogs turning
    ive tried it with jump leads still no go
    question
    can the car be bumped with a broken starter
    ive have had a look at the car
    and so far i can tell you this
    he has no warning indicators or spanner lights
    battery works lights/radio etc still works
    he has removed the battery for upto four hours and my conclusion would have been his ecu after removing battery
    i looked at his key fob and opened it and see no small silcon chip in the head as my 02 plate astra does(but after reading these boards i assume the veccy c 2.0 dti 04 plate dont have the chip
    but the radio has still kept its code
    any help would be greatly appreicated my brother inlaw is not in a finacial postion to get vx to sort so all comments advice would be helpful
    thanks all
    Sunny Dartmoor
    Check the voltage in the battery first,known fault is the battery that just fails........
    Regular Member bill1250's Avatar
    Apr 2008
    Hampshire, England
    Not to technical with this sort of stuff, when did the problem occur, or was it randomly, could be a faulty wire shorting it out maybe or some engine problems. Someone with brains will post soon
    Regular Member simac's Avatar
    Wirral
    It does sound like a dud battery to me. I ran mine flat last year when camping and although it just made a loud clunk when turning the key it still had enough power for the radio to remember the code.
    Does the central locking work ? when my battery was flat the locking went AWOL !
    Apr 2008
    gateshead
    the indicator is still green on the battry all lights come on bright central locking and windows work perfectly
    Apr 2008
    gateshead
    it started when cold then cut straight out tried starting it again and flattned the battery and it clicked when battry whent flat then charged battery fully then all i get is one loud click every time i try to start it
    Wirral
    It could be the leak off pipes, they have been known to go on the DTI but I thought it had been sorted out for the Vectra C's and only a B problem.
    Apr 2008
    gateshead
    well im getting a mobile mechanic out tommorow and hes going to put it on diagnostic i know one thing for sure wont be long before it goes a journey its the only car ive ever had this much bother with will let u know whats happening tomoz thanx 4 the replies any more info would be gratefull as not to get ripped off
    Admin plasma's Avatar
    On the Forum
    312 Post(s)
    Engine : 150
    Mileage : 74000
    If its just clicking with a good battery charge it could be the starter motor itself gone now as well or the fuseable link to it
    Apr 2008
    gateshead
    thats what i thought m8 but should get sumit from a bump or a jump shouldnt i ???????
  1. Help & Advice Urgently Needed
    By lfcfan85 in forum Vectra C / Signum Troubleshooting
    Last Post: 9th November 2009, 20:05
  2. needed urgently
    By andy.l in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2007, 12:42
