Thread: Light Warning Indicator.
    Regular Member Stevie-B's Avatar
    Mar 2007
    NI
    Default Light Warning Indicator.
    My light warning indicator is on constanly even though I've checked all the bulbs and they work fine. Has anyone had this as well?
    Regular Member Dodger's Avatar
    West Midlands
    Just a thought from what I've read on the forum, you say your lights are working, but it could be that one of the rear lamps have failed and the another has taken over, really check the lights carefully to ensure the lamps that should be on, are lit correctly. HTH
    Sunny Dartmoor
    Normally a brake light,iirc..........
    Regular Member B19CBB's Avatar
    Nov 2007
    North East
    Vehicle : Insignia
    Trim : Sri Nav VxLine
    Engine : 2.0 CDTI 160 ps
    Year : 2011
    Easiest thing to do would be take out the rear bulb cluster's and check for a blown bulb, like the guys have said its usually the rear brake bulb which goes, and the running light compensates for this. so can be confusing when trying to see which bulb has blown without removing them.
    11 Post(s)
    The rear brake bulb actually shares its duties with one of the 2 tail lights. If the upper bulb goes, then the lower one takes over as the tail / brake light.
    Bulbs from top to bottom:
    Turn signal light
    Tail light / brake light
    Tail light
    Fog tail light (works on drivers side only - this is normal for the UK)
    Reversing light
    All bulbs are 21 watt.
    Mar 2007
    NI
    Thanks all for the advice. I'll check tonight. Although I did notice that the indicator was working intermittently for a few weeks beforehand.
    Hopefully its somethink simple.
  1. Turn Signal Lamp/Indicator Warning
    By Nimbus in forum Electrical & ICE (including SatNav)
    Last Post: 16th October 2012, 23:58
  2. Intermittent Bulb Failure Warning - Nearside Front Indicator (Problem Solved!)
    By DanR in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2010, 19:20
  3. ****** light out bulb warning and indicator
    By geebee007 in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2010, 02:08
  4. Indicator warning when towing
    By signumturbo in forum Electrical & ICE (including SatNav)
    Last Post: 6th March 2009, 09:30
  5. Help! - Control Indicator for Exhaust Warning Light
    By Madders in forum Electrical & ICE (including SatNav)
    Last Post: 8th December 2007, 20:21
