Thread: please help with baffling problem 2.0 dti vectra
    Jan 2008
    tyne and wear
    Exclamation please help with baffling problem 2.0 dti vectra
    hi all my bro inlaw has been on to here to seek advice about the reason his car wont start
    its a 04 2.0 dti
    had one previous fault (pulley wheel) which vx fixed under warranty
    when you turn the key it clicks like a clunk(i thought starter motor)
    so i tried to bump the car it dont want to know
    it doesnt even make a noise like a car does when you bump it ie belts and cogs turning
    ive tried it with jump leads still no go
    question
    can the car be bumped with a broken starter
    ive have had a look at the car
    and so far i can tell you this
    he has no warning indicators or spanner lights
    battery works lights/radio etc still works
    he has removed the battery for upto four hours and my conclusion would have been his ecu after removing battery
    i looked at his key fob and opened it and see no small silcon chip in the head as my 02 plate astra does(but after reading these boards i assume the veccy c 2.0 dti 04 plate dont have the chip
    but the radio has still kept its code
    any help would be greatly appreicated my brother inlaw is not in a finacial postion to get vx to sort so all comments advice would be helpful
    thanks all
    Regular Member corman's Avatar
    Mar 2007
    hexham
    i know its not much help but regarding the radio, you can overide the code so it doesnt need entering if the power is disconnected, someone may have already done this hence why its kept the code
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    Quote Originally Posted by wreksta View Post
    thanks all
    has he got another key ??????????
    cos if there is a supposed to be a chip in there it will not start due to being immobalised......
    might be completly wrong mind you mate
    Midlands Mod Shop - NFFC.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Bad earth or short of some sort? When the battery is low it just clicks as mine did this weekend but if the batteries in good nick and full charged.....
  1. possible problem with my vectra
    By daz263 in forum Engine & Drivetrain
    Last Post: 9th October 2012, 22:38
  2. Vectra wiper problem - any advice appreciated - Vectra C
    By newbreed in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2011, 20:57
  3. Baffling - replacement CD/Radios with aux in?
    By Mike McGibney in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2010, 15:59
  4. Serious Problem with Vectra
    By Keeks in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2009, 22:30
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
