Thread: Car and Spanner light
    Regular Member Bucko's Avatar
    Pudsey
    Default Car and Spanner light
    Second try.
    Not the oil can and spanner light but the car with the spanner through it is appearing in my tacho display when I switch on. Goes off when engine is running.
    Anyone any ideas please?
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    sound's like it has a fault stored
    Midlands Mod Shop - NFFC.
    Larkhall
    This happened to my Veccy and the car went into limp mode. It cleared itself and i had the car hooked up to a computer but there were no fault codes stored even though that was the second time it had happened
    Full Member Big Sig's Avatar
    Fault code stored mate. You could get it read, but if it doesn't see any faults in a set time, it will erase it
    Pudsey
    Cheers m8s.
    So the only way to find out what it is, is to get it tech2'd to get the faults read out?
    Apr 2008
    Cheshire
    Hi mate
    Sorry if this reply is a little late, the spanner over an engine, this comes on if the car has been stood for some time, moisture gets into the sensor. After driving the car for a time the light should go out but if the car does loose power it will go into a limp mode take it straight to VX dealer...
    Had this problem before last time it was due to a faulty Lambda Sensor if you continue to drive whilst this happens it will damage your cat...
    EB
    Northampton
    i had the same light appearing on the dash this week. got it read this morning but they couldnt find nothing wrong with the car, they said it may just be when the car starts and it will correct itself if its just a error. so dont know going to carry on driving and see what happens.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
