Results 1 to 10 of 14
Thread: Where is the fuel pump/ecu???
    South Wales
    Default Where is the fuel pump/ecu???
    Hi can someone please give me an idea of where the fuel pump/ecu is? I believe it to be behind the battery cover, is it the unit with the small pipes coming out of the top?? Sorry to be a bit blonde....
    South Wales
    i forgot to say i have a 2003 vectra 2.0dti......oooops
    Regular Member Steel's Avatar
    Sheffield
    Trim : SRI CDTI NAV
    Mileage : 202,800
    On to 2.0 dti the fuel pump is located to the left of the engine as you look at it from the front and it had its own ECU (pump control unit PSG5) on top with a multiplug. There is also an engine management ECU connected to the PSG 5 by a CAN system. Most of the test instructions concentrate on the PSG5 control unit, I have never heard of any issues with the engine management ECU on this system.
    South Wales
    hi thanks steel, i cant seem to find it on that side, to confirm its not on the same side as the battery then?
    Sheffield
    Trim : SRI CDTI NAV
    Mileage : 202,800
    If it's a 2.0 dti the pump is bolted to the front of the engine on the left hand side looking from the front of the car, just follow the pipes from the cylinder head, you can't miss it
    Sheffield
    Trim : SRI CDTI NAV
    Mileage : 202,800
    Don't follow the pipes with the engine running by the way, if there is any kind of leak it can penetrate the skin!
    South Wales
    sorry, not to good with engines... I am thinking of getting a tuning box, i know its risky though
    Sheffield
    Trim : SRI CDTI NAV
    Mileage : 202,800
    Never fitted a tuning box to my old dti but my guess would be that it plugs into the PSG5 multiplug on the pump not into the ECU. Its a wierd type of plug with a kind of diagonal slide lock that holds it in place, this is the same plug used to interrogate the PSG5 controller which regulates the fuelling.
    South Wales
    i am guessing plugs into the top of the ecu then? that seems the right shape as you described it, as its an all in one system with fuel pump, here is the item soo what you think?????
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA:IT&ih=007
    Sheffield
    Trim : SRI CDTI NAV
    Mileage : 202,800
    Thats the baby, it probably tricks the fuel quantity solenoid which is buried inside the pump into letting more fuel it. The fuel quantity solenoid is the electronic bit in the pump that fails by the way!
  1. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  2. Replies: 19
    Last Post: 30th May 2012, 15:53
  3. high pressur fuel pump and fuel regulator ?
    By simplesi in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2010, 12:23
  4. Fuel Pump
    By seanyis in forum Engine & Drivetrain
    Last Post: 6th April 2009, 10:08
  5. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
