Thread: Manifold Question???
    Regular Member amar's Avatar
    London
    confused Manifold Question???
    I have a 2.2 sri.... The manifold appeas to have the cat built in... Question is can I change this to any sports type or fit a different manifold... if so whatdo i do with the two lambda sensor wires???
    Anyone done this?
    Regular Member Vid's Avatar
    May 2007
    In the inventing shed...
    Yeah, I have! Check this thread out...
    http://forum.vectra-c.com/showthread.php?t=45412
    Any questions mate just ask!
    London
    looks great... prob is i have two lambda sensors... one before and one after the cat... how will they be installed i see that the cat is now under your car as in most cars...
    May 2007
    Mine was the same setup as yours was, with the lambda before and after the cat, all in the downpipe.
    Both of the lambda wires' had to be extended to be fitted before and after the new position of the cat.
    May 2007
    You will need to bear in mind though that there is no flange to unbolt the cat from above, only beneath it, so you would need to get a downpipe and manifold from a veb-b or astra if you plan on fitting a cat underneath.
    There are other types of cat you can get, but would be tough to fit in the downpipe tunnel?
    London
    sounds complicated.... what were the gains like? is it worth the hard work?
    May 2007
    I felt the gains straight away, but to be honest it is probably because of my other mods I had already done, that helped the improvement, as they compliment each other. To me it was worth it. I can't say whether you would get any beneficial improvement by just relocating the cat and replacing it with a higher flow one.
    And I am planning more mods too, so it depends how far you want to take it as to whether you think it will be worth it!
  1. Had Inlet Manifold Replaced ..... 1 Question
    By WeDesign in forum Engine & Drivetrain
    Last Post: 14th August 2012, 12:06
  2. cdti 150 egr and manifold question
    By craig-s in forum Engine & Drivetrain
    Last Post: 5th June 2012, 19:04
  3. Another cdti inlet manifold question
    By Diesel Dude in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2011, 23:43
  4. manifold question
    By Graeme01 in forum Engine & Drivetrain
    Last Post: 4th May 2010, 13:10
  5. New manifold question
    By PeteRs in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2008, 19:34
