Thread: where is the starter on a 2.0 dti vectra c
    Apr 2008
    gateshead
    Default where is the starter on a 2.0 dti vectra c
    where can i find the starter on a 2.0 dti vectra c and how can i test if its working
    The starter motor is under the turbo behind a heat shield held on by 3 bolts and a bracket at the rear and an absolute biatch to change really should be tested by an auto sparky to tell for deffo if it's goosed or not !!!!!!
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    m8 but if you can get the car on a ramp then its not so bad
    Apr 2008
    gateshead
    thank 4 replies mate mobile mechanic has got it now so his problem cheers once again 4 the info
    Quote Originally Posted by raymond1711 View Post
    1. Turn Key...
    2. Listen for sounds of engine spluttering into life...
    3. If no sound is heard, repaet steps 2 and 3 till battery dies or engine starts...
    I'm a sarcastic tw*t, I know...
    Cheshire
    Default Starter motor change - 2.2DTi
    I need to change mine too.
    On a DTi Haynes says remove the exhaust system !
    Does anybody know if that is really necessary ?
    pfj
  1. vectra 1.9 cdti auto(150) non starter
    By jay w in forum Engine & Drivetrain
    Last Post: 14th January 2013, 20:27
  2. vectra 1.8 starter problem can you help
    By Les45 in forum Electrical & ICE (including SatNav)
    Last Post: 25th May 2011, 12:38
  3. vectra 1.9d 150 starter motor fuse keeps blowing
    By badgerbaiter in forum Engine & Drivetrain
    Last Post: 8th December 2010, 20:41
  4. starter solenoid or starter cdti 150 help!!
    By veralum in forum Engine & Drivetrain
    Last Post: 27th April 2010, 19:57
  5. Help needed Vectra-C.. Starter motor or... ??
    By SRidale09 in forum General Chat
    Last Post: 22nd November 2009, 21:14
how to remove starter on vectra dti
where is the starter on dti vectra
starter motor vectra c 2.2 dti
changing starter motor vectra dti
vectra c 2.0 dti starter motor removal
zafira 2.0 dti starter motor removal
vectra c 1.9 cdti 150 starter motor m8
how to change a starter motor on a vauxhall vectra
where is the starter motor on a vauxhall vectra
vauxhall vectra starter motor location
where is the vectra c 2.2dti starter motor
vauxhall vectra c sri 1.8 starter motor situated
vauxhall vectra 1.9 cdti starter motor 2008 location
vectra dti starter motor location
fitting a starter motor to a vauxhall 2.0 dti
where is the starter located vectra c
vectra c 2.0 dti starter replacement guide
2.0 dti starter
