Results 1 to 10 of 11
Thread: Removing the egr !
    Regular Member Kcs's Avatar
    Feb 2007
    Tamworth
    Default Removing the egr !
    Was snooping around on a BMW forum the other night,
    and one chap with a 530d had removed his egr valve and just
    capped it off ! he was giving some other guy some advice
    on cleaning them, but he said his engine had run far better
    since doing away with his ! can this be done on the Vecy ?
    and if so, what would the outcome be ? would it do the DPF
    any damage ? it would slow the demand down for replacement
    valves i think ! !
    cheers
    Kcs
    Admin plasma's Avatar
    On the Forum
    247 Post(s)
    Engine : 150
    Mileage : 74000
    The ECU would be looking for values to come back from activating the EGR, if it cant see any values or values are out of range it would kick up the spanner light. Only way would be to reprogram the ECU to tell it there isnt an EGR but this would have to be specially written by vauxhall as there is no setting on tech2 to deactivate it as far as i know.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Default egr
    dont know about capping off but they are prone to failure due to clogging up ,its worth taking it off to clean not forgetting to clean the cavity on the head that's what normaly blocks and stops the valve from working!, ps i note your local?i may b wrong is that pooley lane in your profile pic?
    Feb 2007
    Tamworth
    Yes m8, live up in Birchmoor ! might c u around then ?
    Quote Originally Posted by the-wizard View Post
    Feb 2007
    Tamworth
    Thanks for the reply, it would be better to have it
    written in to a remap perhaps !
    Quote Originally Posted by plasma View Post
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    This thread (and there's others) discusses the EGR blanking issue http://forum.vectra-c.com/showthread...light=blanking
    Feb 2007
    Tamworth
    Default EGR blanking
    Quote Originally Posted by gtr1000 View Post
    Nice one m8, so if you you blank the valve off, but keep the
    valve in place, the ECU will ( should ) be fine ! i should think
    most people suffer minor egr problems on a day to day basis,
    but never really get the valve fixed untill it stuffs up completly !
    if you do blank the egr, you should get more consistant engine
    performance,
    thanks again for the info
    cheers
    Kcs
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Quote Originally Posted by Kcs View Post
    performance,
    cheers
    Kcs
    Blanking it off will throw a Cel & Limp mode, Code description = " Egr insufficient Flow"
    I Know, I tried blanking it !!
    Dean
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    The only real way to get around it without errors would be to set it up so you have blanked the inlet on the engine but you will need to plumb the egr to dump waste gas direct into the exhaust rather than back in. I did more research sine that post and couldnt justify the cost for little if any gain
    Regular Member djr69uk's Avatar
    Midlands
    ...and if either of you happen to spot a Red 55 plated SRi bombing about in Tamworth, especially in Wilnecote - then that's probably me
  1. OP-COM for removing EGR
    By Paul_NI in forum Northern Ireland (RO - Vacant)
    Last Post: 17th September 2012, 19:26
  2. removing wax
    By forde in forum Detailing and Car Care Discussion
    Last Post: 21st March 2012, 08:17
  3. Removing a tow bar?
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2011, 12:08
  4. Wax Removing
    By Wolflinn in forum Detailing and Car Care Discussion
    Last Post: 10th March 2011, 09:33
  5. Tip For Removing...
    By AntB in forum Detailing and Car Care Discussion
    Last Post: 10th August 2009, 17:36
