Results 1 to 10 of 16
Thread: Help please...........please........
    Regular Member Pecojess's Avatar
    Nov 2007
    Aberdeenshire
    Default Help please...........please........
    Hiya people. I followed the missus home today and everytime she indicated left the brake lights started to flash with the indicator, when her headlights were on they also started to flash when she indicated. Checked the bulbs they seem fine. So I changed the bulb holder with the other side which was fine whilst driving and it worked perfectly, can it be the bulb holder unit thats faulty? Oh its a nightmare, means she'll have to drive my veccy!!! please help good people, cant afford to go to a stealer!!!!
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Sounds like an earthing problem!
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    In older cars especially F***ds it was a faulty earth. The light cluster earth would be slightly corroded and it just needed a quick clean and it usually worked.
    So probably slight corrosion on the earth feeding the light cluster.
    Jun 2007
    in a white box
    too slow need shorter answers....
    Nov 2007
    Aberdeenshire
    nooooooo It had been suggested it may be, would that only affect one side?
    Any ideas on how to fix it?
    thanks for your reply mate
    Nov 2007
    Aberdeenshire
    also would the earth be on the bulb holders as the right hand holder didnt do the disco light thing when plugged into the left hand wiring loom
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    If you've swapped the holders from the good side to the bad side and then the bad side was working ok, then I'd say its the earth on the actual unit itself somewhere. What car is it on?
    Jun 2007
    in a white box
    I would take the holder off and look for any exposed metal. This would probably be the earth. It usually a cheap tin strip of metal. Not sure what the Vectra earth is like. Still sounds like a earth problem.
    Nov 2007
    Aberdeenshire
    cheers people, its on her a class (dont start lol!!!) I'll take both the bulb holders in and have a look to see if there is any difference this is pics of the rear holder thats the problem http://www.aclassinfo.co.uk/mypage.11.htm could it be the bits you push the bulbs into that are at fault? any idea where the earth would be from the pics? appreciate all your help guys
    Nov 2007
    Aberdeenshire
    cant see any visible difference between the good and bad unit, this is turning into a nightmare!!!!!!!!
