Thread: Passenger Electric Window Switch
    Essex
    Default Passenger Electric Window Switch
    I have an 03 SRi.
    Recently the fron passenger window switch refused to operate the window. The the boot lock/central locking switch also stopped working.
    I have removed the switch, no loose wires and no change to the operation. I removed it again and this time the locking/boot will work if the switch is pressed hard but still no joy with the window.
    Is it likely to be a break in the wire or a faulty switch block - and if so any part numbers for a replacement.
    The window operates fine from the drivers side switch.
    Thanks for your help....
    [Ex]Admin Duncan's Avatar
    It's more than likely just a dirty contact. Pop the switch out again and give the inside a good spray with electrical contact cleaner (Maplin etc. sell it) and that should sort it.
    Sunny Dartmoor
    Did the same with mine and works a treat and has been for over 4 months now........
    Essex
    Perfect, problem solved, thank you.
    Regular Member MysteryElite's Avatar
    Feb 2007
    North Somerset
    I've now got a very similar problem to this - on mine the passenger switch all works except for winding the window up. Works fine from the drivers door so I suspect/hope a similar solution.
    My question is this - just how easy are the switches to get out? Is it simply a case of carefully levering it out or does the door card have to come off?
    Quote Originally Posted by MysteryElite View Post
    My question is this - just how easy are the switches to get out? Is it simply a case of carefully levering it out...
    Yes.
    ...or does the door card have to come off?
    No.
    Feb 2007
    North Somerset
    Hells teeth that was quick! Thanks!
    Admin plasma's Avatar
    On the Forum
    187 Post(s)
    Engine : 150
    Mileage : 74000
    must be nappy changing time which is why hes made himself scarce and now on here
  1. passenger window switch
    By brod999 in forum General Chat
    Last Post: 28th December 2015, 22:54
  2. Passenger Window Switch
    By Carl83 in forum Electrical & ICE (including SatNav)
    Last Post: 25th January 2013, 17:23
  3. passenger electric window switch
    By larrysSRI in forum Bodywork & Interior
    Last Post: 15th March 2012, 01:16
