Thread: Smoke when starting
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Default Smoke when starting
    Hi guys my friend has a 2.0dti and his exhaust is very smokey when starting. Anyone know what this could be? It does it everytime he starts.
    Thanks in advance
    Regular Member EURO G's Avatar
    n ireland
    hi mate mine does the same and my seat toledo does it as well i just took it as the norm
    Jul 2006
    Northampton
    Trim : Sri
    It didnt used to do it before but he said its only started happening in last few weeks. I have a 2.2dti and dont have this problem
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    What colour smoke? Does it do it if he starts when the engine is hot or just when cold?? I guess it goes fine when it has been started for a short time.
    Does it take a bit more cranking to start than it used to?
    It sounds like a glow plug is not functioning correctly.
    Regular Member deanos's Avatar
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Mine does it in the morning, white smoke, dosent do it when driving tho only when starting in the morning, saying that my VX Cdti Combo van dosent smoke at all.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    White smoke is probably either unburnt fuel, stinks to high heaven of an acrid sweet smell, or simply water vapour from the process of combustion.
    If it's UHC then clearly the fuel isn't burning in one or more cylinders. If it's water condensation, then it is normal.
    Jul 2006
    Northampton
    Trim : Sri
    No it stinks, its when the engine is cold. I mentioned unburnt fuel but dont know a resolution to it. i advised him to clean out the fuel lines with reddex or something similar over the weekend but from there i dont know
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Firstly, I would check operation of each glow plug individually.
    Remove the link wire connecting them all together and check resistance of each one to ground.
    Jul 2006
    Northampton
    Trim : Sri
    Quote Originally Posted by Ste View Post
    Ok, and then...?
    East Midlands
    Quote Originally Posted by deanos View Post
    Ditto....Mine as above,only thing i will say is that when starting with the glows it does'nt smoke,it seems to occur when the temp is just above 3 0r 4 degrees, iv'e put it down to unburnt fuel m8 because mine has no at all from a hot start? ......Is yours the same.
  1. Poor Starting & Thick White Smoke (2.0DTI)
    By Daniel89 in forum Engine & Drivetrain
    Last Post: 4th June 2012, 13:47
  2. Car starting on ez-start then on its own and white smoke.
    By Stoo2k in forum Engine & Drivetrain
    Last Post: 22nd May 2012, 19:07
  3. White Smoke on Starting??
    By Governor in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2010, 12:47
  4. Should my CDTi Spit out smoke on starting
    By stugga in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2009, 22:38
  5. Smoke when starting ?
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 18th March 2008, 20:00
saab 93 2.0 white smoke on the mornings
