Thread: VDA Plug question
    Mar 2007
    Gloucestershire
    Default VDA Plug question
    I have the pre-wired VDA plug on my Vectra and have connected it into an Autoleads lead and it works a treat for my phone kit - the only query I have is that there are 2 jack plugs on the lead, one for the speaker and I wondered does anyone know if the VDA lead also provided the connection for a mic? I had assumed that the two jack plugs were to cater for different size conections and so used a separate mic, but I am now thinking the car has a built in mic as part of the pre-wiring???
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    I thought that the VDA plug has all the connections needed; check if the mic is present under the panel of the alarm sensor/behind the interior front light. VDA, aerial and mic are usually part of the pre-wiring kit
    Feb 2006
    Dorset
    The standard fit mic can be poor fitted to some kits so , plug it in try it with a drive up the road .
    Regular Member willc01's Avatar
    UK Motorway Network + some smaller roads
    Where is the VDA plug and what does it look like? I'd like to see if I've got one? Thanks
    Mar 2007
    Gloucestershire
    cheers for that I will plug it in and see, although as I have already plugged in the standard car kit mic, which works fine I wont rush!!
    Willco1 - if you have the pre-wiring it is behind the glove box. Take out the glove box and then in the top right corner there may be a cable tied up and covered in tape - it will have an 18-pin connector and an aerial lead. By buying the correct Autolead it is literally plug and play into your phone kit (I have a Bury system 8 kit).
    Thanks SRI150, i'll have it out today and have a look.
    Mar 2007
    Gloucestershire
    Quote Originally Posted by willc01 View Post
    It wasn't immediately obvious when I was looking as it is usually taped up and you are on the floor looking up so it is a bit awkward!! GIve me a shout if you need any pics as I will be looking at mine today to sort out the mic wiring so if needs be I can take some pics to point you in the right direction - if you look in the area of the rear of the dash adjacent the stereo you should be ok
    Belgium
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Instructions and pics on where to find the VDA-plug and aerial (on a LHD) are on Schelper his site: http://www.put-schelper.de/telefon.html
  1. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  2. Radiator drain plug question
    By sr_fly in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2011, 20:41
  3. blue plug display into a grey plug vehicle
    By vxpenfold in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2011, 23:09
  4. Stuck sump plug - oil extractor question
    By cheekylemon in forum Engine & Drivetrain
    Last Post: 2nd January 2009, 00:14
  5. Spark plug question
    By Guyver1 in forum General Chat
    Last Post: 9th November 2008, 18:04
