Results 1 to 10 of 16
Thread: Autobox problem
    Regular Member 24vElite's Avatar
    Rustington, West Sussex
    Default Autobox problem
    Car is going back into the dealers on Wednesday to look at the auto box again. Can anyone post the field remedy and text for the 'coolant in the transmission fluid' problem, as I think this is the fault. Can't find the link or details anywhere. Hopefully this will prompt the dealer into contacting VX for a transmission replacement.
    Thanks,
    Wayne
    Nov 2005
    Edinburgh
    Do a search on "V6 auto problem" on the Vectra-Sport site - that should point you in the right direction.
    Feb 2006
    portsmouth
    THE BULLETIN NUMBER IS E0001650 ASK THEM TO FIND ON TIS.
    HOPE THIS HELPS
    AF23/33 transmission - No driving torque because of cooling water in transmission oil
    Models: Engines: Option:
    Vectra-C 2002...2004,Signum 2003...2004 Z22SE| Z32SE| Y22DTR,Z22YH| Z32SE| Y22DTR AF23/33 Transmission
    Complaint: Loss of the transmission functionality in isolated cases. The following symptoms may occur occasionally: - failure codes P0700, P0715 or P0720 set - slight loss of cooling water - sediments in coolant expansion tank
    Cause: Improper function of the sealring at the oil cooler conncetion. This can cause the penetration of a little quantity of cooling fluid into transmission oil.
    Production: An improved oil cooler/radiator has been introduced in production as of VIN W0L0ZCF3541042598 (Rüsselsheim) and VIN W0L0ZCF6848035197 (Ellesmereport).
    Remedy:
    In case of customer complaint proceed as follows:
    If only DTC P0700, P0715 or P0720 is stored please carry out TSB 1685.
    Open the black cover of the valve body on the transmission housing carefully. If water and/or white sediments are found in the cover the transmission has to be replaced together with the oil cooler/radiator assembly.
    Here, there and every where!
    you Vx techy by any chance Rob? You could be a very handy addition to the site.
    by the way.
    Feb 2006
    portsmouth
    yes could be . but sometimes embarrased being a tech seeing all these faults. hope this helps but have only seen this problem a couple of times and on early models.
    Nowt to be embarrased about m8. I'm a service engineer on catering equipment and no matter how well i do my job, things still break! Keeps me in a job, pays the mortgage
    Thanks for your reply.
    Dealer fixed everything under warranty, including replacing transmission and radiator / cooler, plus a few other things. See thread http://forum.vectra-c.com/showthread.php?t=4891
    As Caterman says - be good to have you araound for some inside knowledge - welcome to the forum.
    Nov 2005
    Edinburgh
    Rob,
    Thanks for posting the VIN numbers - at least I can relax (I hope) in the knowledge that my car should have had the improved oil cooler fitted during production.
    Mileage : 000
    Hi Rob. Maybe you could shed some positive light on a subject that has gone on for quite a while. OILBURNER and I have been talking tonight about the "tc" switch, we both have put them on our car,s but neither of them work. Can they be acctivated with the tech 2, do you know.
    Cheers.
    ED.
    Feb 2006
    portsmouth
    Default tc switch
    traction control...... dont know if i can help
    The brake system of the Vectra-C is of a modular design. For vehicles with Z 16 XE and Z 18 XE engines, ABS is fitted as standard and traction control (TC) and the electronic stability program (ESP) are optionally available.
    In conjunction with Z 22 SE, Z 32 SE, Y 20 DTH and Y 22 DTR engines, ABS/TC is standard and ESP is optional.
    The extension from ABS to ABS/TC is contained in the ABS control unit.
    The further extension to ABS/TC/ESP requires an additional yaw rate sensor and a steering angle sensor.
    do you know if you hane tracction control??????
  1. autobox problem?
    By chrislloydie in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2013, 20:49
  2. 2004 vectra c autobox problem
    By craig1 in forum Engine & Drivetrain
    Last Post: 1st September 2010, 20:56
  3. Veccy C autobox problem
    By Del in forum Troubleshooting
    Last Post: 8th October 2008, 16:12
  4. Another 2.2 Autobox Problem
    By paver in forum Engine & Drivetrain
    Last Post: 5th October 2008, 11:59
  5. Please give me some advice Autobox problem ???
    By Woodenman in forum Engine & Drivetrain
    Last Post: 5th April 2007, 20:01
